1 members (+8Rich),
295
35
Topics49,915
Posts838,214
Posts: 215 Likes: 6
Posts: 215 Likes: 6 |
In Arizona we have no humidity but the ambient temp is higher than most. I place a rechargeable Ryobi fan in front after a run and it cools it down nicely.
2018 S&S 110th Beetleback 1934 MX4 Beetleback (in restoration) 1965 Corvette Coupe 327/350
Posts: 237 |
Anywhere I can source that filter ? I'm planning to clock those kilometers in no time ...
Piloting Saint Ex the Morgan
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Can I assume you are asking about the G56 air filter? Order from G56, they are responsive folks and do business happily. I went with the AR Stage 1 for warranty reasons and I can honestly tell you that it made such a big difference that smoking the rear tire is something I have to try NOT to do. And to top it off the engine runs MUCH MORE SMOOTHLY. ![[Linked Image]](https://www.tm-img.com/images/2019/08/27/IMG_0391.jpg) Oddly enough the surface area of the mesh of the filter is smaller than the MMC filter but it works much better and I believe it is the stinger that is provided with the cover that protrudes into the venturi of the EFI.
Posts: 237 |
Where can you source those AR filters ? directly from MMC?
The βARβ filter is an S&S and can be purchased directly from them. I purchased the complete AR Stage 1 kit from Morgan of New England.
I believe the Stealth Muscle Cover is what S&S calls the cover.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
The G56 cover has a larger inside diameter (so a larger space between the filter and the cover and it improved acceleration a lot. I would think that AR filter has the advantage of no cover so a much easier air access
The G56 cover is indeed larger but what filter does it use?
Posts: 1,740 Likes: 57
Posts: 1,740 Likes: 57 |
It uses the standard Morgan/S&S filter.
Andy
And that filter is actually larger than the AR Filter in surface area of the mesh.
