0 members (), 355 guests, and 28 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,214
MossyfromNZ
In Arizona we have no humidity but the ambient temp is higher than most. I place a rechargeable Ryobi fan in front after a run and it cools it down nicely.
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
osten Offline OP
Anywhere I can source that filter ? I'm planning to clock those kilometers in no time ...
Piloting Saint Ex the Morgan
Can I assume you are asking about the G56 air filter? Order from G56, they are responsive folks and do business happily.
I went with the AR Stage 1 for warranty reasons and I can honestly tell you that it made such a big difference that smoking the rear tire is something I have to try NOT to do. And to top it off the engine runs MUCH MORE SMOOTHLY.
Oddly enough the surface area of the mesh of the filter is smaller than the MMC filter but it works much better and I believe it is the stinger that is provided with the cover that protrudes into the venturi of the EFI.
osten Offline OP
Where can you source those AR filters ? directly from MMC?
The β€œAR” filter is an S&S and can be purchased directly from them. I purchased the complete AR Stage 1 kit from Morgan of New England.
I believe the Stealth Muscle Cover is what S&S calls the cover.
The G56 cover has a larger inside diameter (so a larger space between the filter and the cover and it improved acceleration a lot. I would think that AR filter has the advantage of no cover so a much easier air access
Rodger
2004 Plus 8 (wife's)
The G56 cover is indeed larger but what filter does it use?
It uses the standard Morgan/S&S filter.
Andy
And that filter is actually larger than the AR Filter in surface area of the mesh.
