2009 Plus 4 - Does the plug to the fuel pump need a special tool or technique to unclip it? I don't want to force it!
Does anyone know what the spare connectors are for on the wiring loom that goes to the fuel pump?
If its the same rear loom as shown on diagram for later V6 (MEH1243) then there are four connectors in the fuel tank area:
Evap canister vent solenoid (2 pin), fuel tank pressure transducer (3 pin grey connector), fuel pump transducer (4 pin flat connector), fuel pump and sender (4 pin blue connector)
