1 members (Ian B),
267
Posts837,990
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
I have a gdi plus4 and have had the ECU remapped by Williams Morgan -- fantastic result -- I had wanted to do it as I was told it would improve the MPG -- well... it did improve the MPG - from average33 to average 40 BUT .. it also gave a big improvement in grunt from about 2500revs --I do NOT have a fancy manifold, just the standard one -- Best value upgrade ever for the Mog!
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
I was always told I would have to have a fancy manifold for a reflash / chip on a GDI. Is this a Morgan modification or one they have acquired from elsewhere?
Was it expensive if it’s not too rude to ask?
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
The manifold & cat is an Aero Racing part. Originally sold as a full system, you might be able to buy the manifold & cat. But you won't get the twin tailpipe.
The whole system comes in around £2k
Librands also do a manifold & cat.
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
I have read this and other threads on the subject and am still not sure on the advice. I have a Duratec Plus 4 and am attracted to the idea of a re-map but do not have the fancy manifolds, is it worthwhile going ahead. My plus 4 Duratec has a Williams manifold, exhaust and remap. I had occasion to put it on a rolling road (emissions issue) and power had increased to 155 at flywheel and torque to 148@4800rpm. You certainly won't get the results with a Duratec that you will with the GDI.
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
I believe it is the club sport map, Hawki— cost circa £300 Cheers!
Posts: 27,835 Likes: 760
Posts: 27,835 Likes: 760 |
Gary buy the +6 in December you know it makes sense.
Posts: 697 Likes: 7
But what does Head Office say?
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
I have read this and other threads on the subject and am still not sure on the advice. I have a Duratec Plus 4 and am attracted to the idea of a re-map but do not have the fancy manifolds, is it worthwhile going ahead. My plus 4 Duratec has a Williams manifold, exhaust and remap. I had occasion to put it on a rolling road (emissions issue) and power had increased to 155 at flywheel and torque to 148@4800rpm. You certainly won't get the results with a Duratec that you will with the GDI. I had emissions issues with the Aero Racing manifold and cat (same manifold and cat as the Plus 4 SS) fitted to my car at the factory. I resolved the problem by fitting individual throttle bodies and a Omex ECU so that I could do my own tuning. How's that for logic
Posts: 327 Likes: 3
Posts: 327 Likes: 3 |
I was wondering how / whether these mods affect the stated European emissions ratings for the standard engines. This is becoming a issue for using the car in some cities.
Tom 2018 Plus 4
