4 members (+8Rich, WJH, Vansrv6, MartinB60), 285 guests, and 40 robots.
John V6 71
DaveW 67
+8Rich 65
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts812,981
RedThree
Page 2 of 6 1 2 3 4 5 6
2Sharp #613370 21/01/20 12:52 PM
I tightened mine (it was REALLY sloppy from the dealer) and then kept rotating the wheel until the belt seemed to stay center. then I ran it (tire up) to recheck. I guess I just remember the older motorcycles where centering the wheel was as much art as mechanics
Rodger
2004 Plus 8 (wife's)
2Sharp #613414 21/01/20 04:15 PM
2Sharp Offline OP
Thanks. Love the video. I agree the belt centering is as much of an art. I am going to leave it alone and not over think it.
2017 M3W Sport Green
2Sharp #613434 21/01/20 06:24 PM
As long as it doesn't jump teeth its fine, you can over think it, I have been there!
Dab of oppo #613484 21/01/20 10:48 PM
Originally Posted by Dab of oppo
This is mine in motion.
https://youtu.be/ZKTt3i1cmQg
Did you center the drive belt with the adjusters and then tighten the axle not?
How do you judge what is tight enough on the axle nut/nuts?
2Sharp #613544 22/01/20 12:47 PM
tighten it until it breaks and then back off 1/4 turn....
Rodger
2Sharp #613860 24/01/20 09:05 PM
OK, I centered the belt using the adjusters and put the proper slack into the belt. All is well there so I went to tightening the axle nut.
I noticed that the rear wheel was not spinning as freely when the vehicle was on my lift. The brake seems to be dragging, maybe the auto adjusters have not taken their position yet? It spun freely without the axle nut being tightened.
Any ideas?
2Sharp #616308 09/02/20 04:57 PM
I found my mistake in reassembling the rear axle assembly. I put a washer on the wrong side of the axle, primarily because the drawing from Morgan leaves it out.
I put the third washer on the drive belt side and it should have been on the brake side of the axle. It is number 11 part on the exploded view and that view only shows 2 washers where there should be three. I added it in this crude sketch but I believe you get the idea. The third one should be between the adjuster and the drum backing plate mechanism.
2Sharp #616333 09/02/20 07:09 PM
2Sharp #616334 09/02/20 07:11 PM
2Sharp #616335 09/02/20 07:14 PM
url=https://servimg.com/view/11862231/2463][Linked Image][/url]
