1 members (RichardV6), 251 guests, and 40 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
#616774 11/02/20 07:10 PM
Or should it be 'bleedin clutch'
3.7 Roadster, done a full pipe trace all the way to the entry into the bellhousing / slave cyl and can't find a bleed point anywhere, had mirror on a stick, tried everything ??
Easy peasy on the 3.0, done a few in the past
Anyone got a clue please ?
Online NoMood
It a concentric slave cylinder Jon so will be inside the bellhousing as shown below (3). Seems it doesn't have a bleed nipple though.
ETA: I believe vacuum bleeding at the m/cylinder end is the preferred method after intercepting reservoir to m/cyl pipe. Various YouTube video's describing method.
Give a Morgan dealer a call. Most service departments are happy to give guidance to the enthusiastic amateur.
I had to seek guidance from Allon White when I swapped engines in my 4/4 and they were very helpful. (Although I suspect they rolled their eyes after I put the phone down)
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Richard, yes I came to the same conclusion & your image is helpful
A proper PiA for the bi-annual fluid change banghead
I seem to remember that the concentric slave cylinders I saw being installed a few years ago were pre-filled with fluid and had no bleed
Mike Smith
2007 +4
II had same problem, had a leaking/loose fitting near bell hosing on my 2012 Roadster. After filling and tightening joint. mechanic said to pump it and it will come right. Took about 50 -60 km and it did.
Morgan Roadster 3.7 2012 Spruce Mica Green Saddle Brown Interior
Randall #617080 13/02/20 02:25 PM
Thanks Randall thumbs
