1 members (Saxonian),
333
Topics49,904
Posts838,088
Posts: 5,470 Likes: 476
Posts: 5,470 Likes: 476 |
I can remember seeing Datsun cars with plastic plugs screwed into the base of the track rod ends in the early 70`s. The plastic plugs could be removed exposing a pre threaded hole that accepted a grease nipple... I had a few Datsuns, and neither greased or required to replace a track rod end on one... Recently replaced what I imagine were the original track rod ends on my mid 80`s +8 at circa 30k miles as the result of the boot having cracked with age..No obvious wear in the track rod joints.
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
My Dolomite had three U/Js on the prop-shaft. Each spider had a grub-screw, which had to be located, removed without losing, and then a nipple screwed in. This meant rotating the back wheels to find the grub screw. What fun that was. The clearance to leave the nipple in place was very marginal.
Posts: 7,435 Likes: 122
Posts: 7,435 Likes: 122 |
Sometimes it happens to me that I don't leave the nipples in place. It also involves rotation. Sorry for this sort of immature and ancient joke, but in this case I could not resist.
Posts: 132 |
Update!
I took the car to a tyre garage to set the tracking. He was somewhat confused, and it ended up with it being a joint effort.
The net result was a really good set up!
Happy with that, though can you hire the laser aligners? It might well be cheaper...
New tyres, next.
