Topics49,908
Posts838,124
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
![[Linked Image]](https://www.tm-img.com/images/2020/02/14/Thumb-Screw-1-of-1.jpg) After years of cursing my inability to make things beyond a certain point usually ending in another cry of "if only I had a ****ing lathe" followed by "and had the faintest idea of how to use it" I have now done the deed and have set up a workshop in my old coal shed. The lathe had sat unused for years in a corner of the workshop at the company I work for and is now in "safe storage" in my shed. Took a fair old clean up and sort out to get it working properly* and has now been used in anger, or at least a mild fit of pique. The picture is of the very first thing I have ever made on a lathe, is only a bit rough, and if I can manage another ten of them I will have a new set of screws for the boot liner! Could take a while.  *at least I think it's working properly!
Posts: 542 Likes: 7
Posts: 542 Likes: 7 |
The therapeutic properties of owning and using a lathe are greatly underestimated!
Certainly needed a fair bit of therapy after getting it out of a van, through the tenement, across the back garden, into the shed and up on to the bench on my own!
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Impressive Calum  Last time I cut a thread on a lathe was in the 1960's. Quite gratifying just using a die successfully a couple of weeks ago.
Posts: 1,031 Likes: 2
Posts: 1,031 Likes: 2 |
That looks to me like highly skilled work. Now you can emulate the chap who is using his lathe to fabricate an entire three wheeler.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
just remember to not wear a tie whilst using the lathe
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
just remember to not wear a tie whilst using the lathe Or anything loose!!! Great job Calum.
Posts: 3,383 Likes: 14
Posts: 3,383 Likes: 14 |
Something to be proud of, well done. I feel the pain as I once bought a Myford 7 Lathe, lots of tools, read books and all I made was swarf. Went to see my pal Peter Mulberry (Mulfab) who gave me a crash course, 3 weeks later and after a lot of practice I had made a spacer washer for my +8's lower air scoop.
Forever known after that day as the £1800 washer...…. you know its easy to hate other Morgan owners, especially when they are right ;-)
BR Colin (keep practicing your on the right track I could never have reached where you are already)
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
- you are my 'Knurling' hero Calum  James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
![[Linked Image]](https://www.tm-img.com/images/2020/02/14/Thumb-Screw-Four.jpg) Screw count has hit four! Well known fact; a machinist should be able to make anything to any size and I can certainly guarantee that no two dimensions match across the four screws! There's versatility for you. Despite appearances I did use the same knurling tool in the same manner for all four of them but I am now all knurled out. I did cheat with the thread cutting and used a die, got a feeling I would be really pushing my luck trying to cut an M5 thread up to a shoulder on the lathe at this stage of the learning curve. It's been frustrating enough getting to where I am; luckily the lathe is securely bolted down on to a substantial bench so would be really difficult to throw out of the pram! Dinner is now in the oven and I've just opened a fresh bottle of what hopefully will be a very pleasant Argentinian red cutting fluid.
