8 members (Lance, M3WMW, SEG, cerealsurfer, +8Rich, Hamwich, stumog, Black Adder),
212
48
Topics49,909
Posts838,126
Posts: 128 |
Hi all, whilst carrying out some changes to "Marty" my 2011 Plus 4 I was considering how the front grill area would look powdercoated in a satin black? Has anyone done this sort of modification/change? How simple to take the grill off? John
Posts: 22,371 Likes: 354
Posts: 22,371 Likes: 354 |
The grille is held by the two bolts visible on the bottom trim. Remove them and the grille slides down and out.
If you have a number plate box, you must first remove the number plate and box.
Beware that when refitting it's easy to chip the paint on the bottom corners of the wings because the fit is loose.
Earlier cars had rivnuts on the lower panel, but you may just find oval holes.
While I was inside the cowl, I added a carbon fibre panel on the bottom, and neoprene covers on each side to duct air through the rad instead of round the edges.
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
How big is your cowl Dave, I just can't visualise you inside it !!
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
How big is your cowl Dave, I just can't visualise you inside it !! Dave's not very tall.
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Hi all, whilst carrying out some changes to "Marty" my 2011 Plus 4 I was considering how the front grill area would look powdercoated in a satin black? Has anyone done this sort of modification/change? How simple to take the grill off? John Looks great (I think) powder coated silk black. Had headlamp rims and overriders done at the same time. £70 all in ![[Linked Image]](https://i.imgur.com/52Zr75q.jpg)
Posts: 51 |
Hi all, whilst carrying out some changes to "Marty" my 2011 Plus 4 I was considering how the front grill area would look powdercoated in a satin black? Has anyone done this sort of modification/change? How simple to take the grill off? John Looks great (I think) powder coated silk black. Had headlamp rims and overriders done at the same time. £70 all in ![[Linked Image]](https://i.imgur.com/52Zr75q.jpg) Next the wheels ?
Mercedes Sprinter 308 2001 VW Passat Station 2011 Morgan 4/4 1980
How big is your cowl Dave, I just can't visualise you inside it !! Dave's not very tall.  You guys are almost as funny as Kev.
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
