Morgan Aero 8
0 members (), 230 guests, and 23 robots.
+8Rich 93
John V6 49
Posts837,990
rockabilly john
#61981 16/05/11 02:03 PM
My remote key fob won't lock the car any more. I suspect it's a sensor issue and not a key fob issue (the light is still lighting up on both key fobs indicating the batteries are fine).
Can anyone give me some pointers as to how I can go about diagnosing/fixing this issue? I'm not even sure where the sensor is in the car blush
Mr Fezza
Mr Fezza
New battery always fixes it. Led will light up but the power required for the transmitter is much higher. Had his happen on two aeros, each time a new batter solved things. It's a cheap fix...
Maxxed out!
I'm inclined to agree with Rich.
Try new batteries before anything else.
Had the same issue and solved in the same way.
Batteries are CR2016, for reference.
If you find as I did that it was non of the above. I have the fix. Good luck and I hope its just the battery and not the control relay unit. cheers
Graham
For now it was the batteries, but with this car you never know what could happen the next morning laugh
