5 members (Nick55, BHV, ChrisConvertible, DJC, Plus Four Guy), 330 guests, and 41 robots.
+8Rich 101
John V6 66
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,919
Posts838,266
Smed., Spanner Juggler
dale2 Offline OP
Hi All, I have a dashboard out of a 67 4/4 that I am restoring and it is all weathered and checked. I cannot tell if it is veneer or heavy shelac. Has anyone ever refinished one of these or do I make a new one? Will a laquer thinner loosen the finish or should I sand it, or should I cut a new dash? Any help with this project would be appreciated. Dale
Strip the old finish with a commercial paint remover.
Sand with fine garnet paper to remove residue.
Re-coat with marine varnish. Thin coats block sanded in between coats with 600 grit wet or dry paper to get a uniformly flat surface with no low or high spots. Sand final coat with 600 grit paper which will leave the finish mat. Polish to a satin finish with a felt block and pumice using mineral oil as a medium. Polish to a high gloss with felt pad and rottenstone.
'65 +4 four seater
dale2 Offline OP
Thanks for the information, I will try that, I have cut a new dash but I would like to try to restore the original if possible. One question, Do you use a stain after stripping? Dale
If the wood is uneven after sanding, you can stain it to make it more uniform
'65 +4 four seater
