1 members (cerealsurfer), 334 guests, and 84 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Yes, Easter, that is exactly what I had in mind, though I would take a string which is a little more substantial (to give better grip).
Vitruvius, are you sure about the itchy twine? I prefer a smooth "surface" because it is friendlier to the skin when the wheel is gliding through the hands (which is impossible in my 4/4; it has practically no self centering).
Sorry about the PM, I meant a private email-address to where I can send you pictures.
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Thanks for the photos Easter. Great reference for different wheels as well. Looks like wood makes a better long lasting material for a steering wheel than bakolite.
Reade
'67 +4 tourer - broken white - RHD
Well, I finally did it. I took off the steering wheel and wrapped it with 3/16" stretchable cotton clothesline. It is very comfortable to the hand. It worked great. I will post a picture. It was easier than I thought to take the wheel off. I took off the bolt with a wrench and a towel so not to mar the chrome, then jiggled the wheel for about 3 minutes until it finally broke loose and came off. It is an amazingly tight fit on the grooved shaft. I fell back only 6 inches or so. LOL.
Thank you Phantod, Bodger and Easter.
Did you end up getting your 3 spoke steering wheel ? maybe you ended up with more than one ! I am looking for one can you assist. ?
Originally Posted By Bodger
Take off the chromed centre bolt and pull. Sometimes it needs a little persuasion to brake loose.
A small hub-puller is very useful for achieving this.
1972 4/4 2 Seater
Best to use a hub puller to save damaging the splines by "wiggling" the wheel free.
