8 members (Supermog, BLUE+4, Ruut Bianchi, GrumpyPa, MATTMOG, TalkMorgan, nick w, Mark+4),
274
Topics49,912
Posts838,160
Posts: 5,608 Likes: 617
Posts: 5,608 Likes: 617 |
Who would have guessed so many came to grief! ...... K
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
I think that this breaker’s yard is about 30 minutes drive from Williams. I wonder if they’ve had a look? It could make a good “Friday afternoon” workshop project for them?
Bud 4/4 "Stanley"
Posts: 37,489 Likes: 993
Posts: 37,489 Likes: 993 |
The address is given as Lancashire Bud  Stay safe up there near Exetree way.
The address is given as Lancashire Bud  Stay safe up there near Exetree way. Oops!  I clicked on the map below their advert, which actually referred the the following advert. All OK here. We are isolating, though plan the occasional walk along the now deserted beach. Also I’ve been trying to work out what number to set the pressure washer to, should we run out of loo roll!
Bud 4/4 "Stanley"
The address is given as Lancashire Bud  Stay safe up there near Exetree way. Oops!  I clicked on the map below their advert, which actually referred the the following advert. All OK here. We are isolating, though plan the occasional walk along the now deserted beach. Also I’ve been trying to work out what number to set the pressure washer to, should we run out of loo roll!  Good to hear you're ok, likewise here going to have a few runs over the Moor to keep things moving, a flask and a piece on board will be the plan. When you find out the setting let us know it could be painful else
Posts: 3,565 Likes: 14
Posts: 3,565 Likes: 14 |
The address is given as Lancashire Bud  Stay safe up there near Exetree way. Oops!  I clicked on the map below their advert, which actually referred the the following advert. All OK here. We are isolating, though plan the occasional walk along the now deserted beach. Also I’ve been trying to work out what number to set the pressure washer to, should we run out of loo roll!  It's not so much the pressure you need to worry about, rather the setting for the jet shape. I suggest you try the fan shape before the needle shape Bud. As Richard says, if you do the research, don't hesitate to let us know the results...............
Posts: 516 Likes: 1
Posts: 516 Likes: 1 |
They obviously know their Morgans. This one has no wooden chassis because it's got to be crushed....
Malcolm T 1966 +4 1957 TR3 1963 TR4 1983 LR 110 1985 Robin Hood 2.0l
There's a dark colour Aero in the background with it's hood up too Here it is Jon, appeared on another post this morning under the same Breakers Yard.. 2006 Aero Spares
Posts: 8,703 Likes: 501
Posts: 8,703 Likes: 501 |
There's a dark colour Aero in the background with it's hood up too Here it is Jon, appeared on another post this morning under the same Breakers Yard.. 2006 Aero SparesYes, saw that, lots of salvageable bits but was obviously bumped hard enough to trigger both airbags
