9 members (Joske Vermeule, WAFU_Tom, Steve +8, +8Rich, jbk, mph, Mogdavid, Sir Percival, Alan Patterson), 251 guests, and 51 robots.
+8Rich 89
Luddite 50
Posts837,957
#625076 23/03/20 06:41 AM
Hi
Service time for the Plus 4. I have searched here but can't find a thread on this and Dave's book does mention the air filter. So does anyone have details of a non Morgan sourced air filter for a 2012 Plus 4, please? It can't be a Morgan special as the housing doesn't fit properly and rubs on the bonnet. Then again..... ;-)
Thanks
Nick
Originally Posted by Nickplus4
Hi
Thanks
Nick
Are you asking what filter element to purchase to replace the existing one as a routine service item or do you want to change the whole filter unit to something else, such as a K & N ?
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Could you please post a picture. That might help
Thanks both.
I am after the existing spec - I don't need a high performance filter. Just trying to reverse spec from the K&N version.
John - it looks the same as Dave's top picture on the thread he sent.
Suggest you use e bay or the web to look then for the K&N part number. It should lead you back to the original.
The airbox should be the same so then I wonder at your comment "It can't be a Morgan special as the housing doesn't fit properly and rubs on the bonnet. Then again..... ;-)"
I wold imagine it is the original morgan part.
I meant that if it had been a unique Morgan part, it probably would have fitted under the bonnet properly - so I think it must be an off the shelf part from another vehicle?
And with all your help I have found it - many thanks. It appears to be from a Mk3 Ford Mondeo 2.0 TDCi from 2000-2006
Thanks Folks
I understood Nick that the filter fits well into the airbox but the airbox does not fit so well into the car. This is at least the case with my Sigma 4/4. The Fiesta airbox fits but MMC has filed off the edges of the housing in two places to prevent it from rattling against other parts in the engine compartment.
