3 members (Montegue, Plus Four Guy, Grumpy2), 209 guests, and 58 robots.
+8Rich 62
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,762
#627328 01/04/20 07:53 AM
Grumpy2 Online Content OP
OP Online Content
in light of the fact I've nothing better to do and in an attempt to solve my 'swish swish' noise on braking I've decided to fit new rear brake shoes to my 94 plus 8. (auto adjusters)
Ordered from BHM on Monday they should arrive today. Much tooth sucking and warnings of how difficult is is from BHM.
Any tips here before I get going? Obviously there's no rush!
Thanks
Gary
Long nose locking pliers to grip the springs. Take photos before you start.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Slacken off the handbrake cable before you start, it's just under the saddle board.
Take your time with it Gary
It will look similar to this...….
Note that the shoes have a different lining thickness. The leading shoe is thicker....this is offside. Yours being older may use linings the same thickness, but take photos before you start.
The shoe retainers are 8 o'clock and 3 o'clock.
Back the handbrake off as Richard said. The new shoes will need it well slackened to get the drum back on, and the shoes must be perfectly concentric with the drum.
If you have a raised rusty lip inside the drum, remove it.
The linkages are quite complex, so photograph close up.
It's also recommended that you chamfer the leading edge of the shoes, so on this image, 1 o'clock and 7 o'clock.
After refitting the drum, stamp on the brake pedal, and yank the handbrake a few times to centralise everything.
Check that the drum rotates reasonably freely, but expect some light rubbing until the shoes bed in.
Finally re-adjust the handbrake.
E
E
These can be handy but not essential.
https://www.ebay.co.uk/itm/Brake-Spring-Washer-Double-Sided-Installation-Removal-Tool-Durable-Steel-New/352214702266?hash=item5201a1d8ba:g:3FcAAOSwT6pVzfRW
Good video based on a +4. Probably same principle for your car
https://www.morganexperience.com/fo...e-rear-brake-shoes-morgan-4-93-on.12027/
Ragnar
2000 mod +4
OP Online Content
yep, I've spotted the video - pity its not narrated and only shot from one angle. But definitely helpful, thanks.
Gary
