Topics49,899
Posts838,024
Posts: 224 Likes: 13
Posts: 224 Likes: 13 |
I have recently fitted a new carb on my car (all working OK) but I am curios to know what this inlet/outlet is for. I have pushed a probe up inside but it just hits a blank, so I'm not sure if it actually does anything. Can anyone enlighten me please? ![[Linked Image]](https://www.tm-img.com/images/2020/04/09/New-DGV-1.md.jpg)
Roadster 3.7 Plus 4 110 Anniversary Plus 4 Fiat TC
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
Vacuum advance and retard?
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Vacuum advance retard take off when fitted to a Ford crossflow.
Is the carb number 32/36 DGV 5A? stamped into the base flange
Arwyn
Posts: 6,676 Likes: 441
Posts: 6,676 Likes: 441 |
Yep, just checked mine and as said above Vacuum advance from distributor
As I don't have vacuum advance on my distributor should I blank it off? As I said previously I did insert a probe but it hit a hard surface, but I'm not sure if there is a channel that goes off at right angles inside. I suppose I could put my finger, or soap suds, over the hole and rev the engine to see if it sucks?
Makes sense to blank it off even if it appears blocked.
Arwyn Yes it is stamped DGV 5A.
Posts: 19 |
This is the incorrect carburettor for this car. Email me direct.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
This is the incorrect carburettor for this car. Email me direct. Curious as to what the correct carburetor is?
Looks a new carb so still under warranty so I'd not advise crimping the brass tube to close it.
Bit of close fitting rubber tube with an m4/m5 bolt in it to blank it off.
If the cars running ok with it I don't think theres much point in changing the carb
Arwyn
