3 members (JohnHarris, Player99, mph), 244 guests, and 38 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
#629264 09/04/20 08:41 AM
BigLes Offline OP
I have recently fitted a new carb on my car (all working OK) but I am curios to know what this inlet/outlet is for. I have pushed a probe up inside but it just hits a blank, so I'm not sure if it actually does anything.
Can anyone enlighten me please?
Roadster 3.7
Plus 4 110 Anniversary
Plus 4 Fiat TC
Vacuum advance and retard?
Vacuum advance retard take off when fitted to a Ford crossflow.
Is the carb number 32/36 DGV 5A? stamped into the base flange
Arwyn
TBM Offline
Yep, just checked mine and as said above Vacuum advance from distributor
BigLes Offline OP
As I don't have vacuum advance on my distributor should I blank it off? As I said previously I did insert a probe but it hit a hard surface, but I'm not sure if there is a channel that goes off at right angles inside. I suppose I could put my finger, or soap suds, over the hole and rev the engine to see if it sucks?
Roadster 3.7
Plus 4 Fiat TC
Makes sense to blank it off even if it appears blocked.
BigLes Offline OP
Arwyn
Yes it is stamped DGV 5A.
Roadster 3.7
Plus 4 Fiat TC
This is the incorrect carburettor for this car. Email me direct.
Curious as to what the correct carburetor is?
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Looks a new carb so still under warranty so I'd not advise crimping the brass tube to close it.
Bit of close fitting rubber tube with an m4/m5 bolt in it to blank it off.
If the cars running ok with it I don't think theres much point in changing the carb
Arwyn
