2 members (sewin, Tony Quinn), 262 guests, and 53 robots.
+8Rich 90
Luddite 50
Posts837,962
Page 7 of 8 1 2 3 4 5 6 7 8
Test assembly with a wooden board ... :
Lille - France
Plus Four 2024
What lamps do you plan on putting into those large buckets?
Hi
I need to replace my headlight buckets, where did you get yours ?
Thanks
Nigel
headlamp shells
Probably not economical to order from the UK, but this should give an idea of the price.
Thanks John
Holden's shell does not show a mounting bolt
I think to put the same LED spotlights as in the main lights
I bought a new lot at a good price from a member of the MTW France club (light support arms, headlight casing, optics, indicators, wiring harness) for only 120 euros....
Lille - France
Plus Four 2024
Nestor your new lamps are very low & the same lights as your headlamps would just dazzle other drivers. Perhaps a wide beam fog light or spot wired into main beam that would go off on dip.
Hella 500 series fog lamps are a very effective fog lamp with a pronounced cutoff line. I used them on my mini coopers.
There is a better but more expensive option for replacement headlight shells from SVC p/n AS700B for black and S700SF for stainless steel. These have the right fitting as well.
