10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike),
273
42
Posts837,969
Posts: 875 Likes: 157
Posts: 875 Likes: 157 |
Lille - France Sold : MTW 2012, 4-4 Sport 2010, Roadster V6 2008, Super3 2024 Plus Four 2024
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
What lamps do you plan on putting into those large buckets?
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
Hi
I need to replace my headlight buckets, where did you get yours ?
Thanks
Nigel
Posts: 902 |
headlamp shellsProbably not economical to order from the UK, but this should give an idea of the price.
Posts: 398 Likes: 1
Posts: 1,947 |
Holden's shell does not show a mounting bolt
I think to put the same LED spotlights as in the main lights I bought a new lot at a good price from a member of the MTW France club (light support arms, headlight casing, optics, indicators, wiring harness) for only 120 euros....
Posts: 1,947 |
Nestor your new lamps are very low & the same lights as your headlamps would just dazzle other drivers. Perhaps a wide beam fog light or spot wired into main beam that would go off on dip.
Hella 500 series fog lamps are a very effective fog lamp with a pronounced cutoff line. I used them on my mini coopers.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
There is a better but more expensive option for replacement headlight shells from SVC p/n AS700B for black and S700SF for stainless steel. These have the right fitting as well.
