Topics49,911
Posts838,142
Posts: 128 |
Hi Guys, So that I don't do any damage to my new Blaupunkt Head Unit when fitting, I was hoping someone might be able to advise on the Morgan's Radio Pre-Wired Plug(s)? I know that the Brown Plug has the Speaker Wires but the Black Plug has me a little confused as it is not colour coded like the plug that came with the Head Unit. The Morgan's plug has 8 pins of which there are only 4 coloured wires, as follows: Black (Ground?) Green/White Purple/Red Orange/Red I am sure that they will be for: Switched 12v feed, Direct 12v feed and Illumination, however I have not got a clue which and am a bit surprised that the factory didn't go with the traditional three main power colours of, Red, Blue and Orange? Anyone able to assist? John Morgan Plus 4 (2011)
Posts: 542 Likes: 7
Posts: 542 Likes: 7 |
When I fitted my Pure radio.CD into my 2013 plus 4 it was a straightforward "click and connect" and no alteration to wiring./plug was needed.
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
The factory plug fitted my Sony perfectly. From memory it is DIN standard.
Posts: 1,065 Likes: 23
Posts: 1,065 Likes: 23 |
Yes, the usual 8point connectors are just "plug and work". Only Volkswagen has sometimes changes alltime power and ignition power.
I fitted two radios (changing from a bluetooth to a "Fernbedienung"), both in and work.
René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
Posts: 8,702 Likes: 416
Posts: 8,702 Likes: 416 |
Hi Guys, So that I don't do any damage to my new Blaupunkt Head Unit when fitting, I was hoping someone might be able to advise on the Morgan's Radio Pre-Wired Plug(s)? I know that the Brown Plug has the Speaker Wires but the Black Plug has me a little confused as it is not colour coded like the plug that came with the Head Unit. The Morgan's plug has 8 pins of which there are only 4 coloured wires, as follows: Black (Ground?) Green/White Purple/Red Orange/Red I am sure that they will be for: Switched 12v feed, Direct 12v feed and Illumination, however I have not got a clue which and am a bit surprised that the factory didn't go with the traditional three main power colours of, Red, Blue and Orange? Anyone able to assist? John Morgan Plus 4 (2011) Pin 7 Black = ground Pin 8 Light green/white = switched +12 volts Pin 3 Purple/red = permanent +12 volts Pin 5 Red/orange = light feed (if used/present) Note on later models 2014 on, the purple/red permanent feed is replaced with brown/blue cable.
Posts: 128 |
Thanks Richard, As the sun was shining and I had nothing better to do, found my long lost "Circuit Tester" and came to the same conclusion. Will probably splice into the switched feed for the power (Blue Cable) to the dab splitter, would you agree? Cheers, John
Posts: 586 Likes: 21
Posts: 586 Likes: 21 |
I fitted my dab splitter to the live feed, as I like to listen to music whilst working on the car. No problems with drain so far, and my Blaupunkt auto offs after an hour.
"DOT" 35th Anniversary Edition Plus 8- family owned from new. Rolls Royce Pewter. 06 Saab 93
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
Just fitted a new system. The two plugs are DIN standard so they are plug and play. I also squeezed in (literally) a DAB aerial splitter and that needed a power connection but that was provided for on the short harness that came with the system.
Thanks Richard, As the sun was shining and I had nothing better to do, found my long lost "Circuit Tester" and came to the same conclusion. Will probably splice into the switched feed for the power (Blue Cable) to the dab splitter, would you agree? Cheers, John That sounds fine John. On my Sony radio its own short loom had a spare yellow cable for electric aerial extension that I used for DAB splitter power.
