4 members (BobtheTrain, IcePack, Zach, Rog G), 238 guests, and 42 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Page 3 of 3 1 2 3
Thanks for all your suggestions folks , much appreciated. I had wrongly assumed that my tatty box of ring terminals from Fleabay were the only ones available. I have now learnt otherwise. As you have suggested I will now change the ring connectors to a larger version and add a 15amp inline fuse.
2015 Plus 4 (GDI) Sport Green
I note that on two of my 3 chargers there is an inline fuse, I will add a fuse to the third.
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Posting Desperado
Posting Desperado
Originally Posted by Tonyh157
I just plug mine into the cigarette lighter socket, saves all this extra work and works a treat!
Been doing it for years even got a plug in double socket for the lighter socket . I run the dash cam and sat nav from it
When I got my car I found a little cable with a plug at the end with three LED’s, red, amber and green, I found out this was for plugging a Ctek charger into and is permanently connected to the battery (with fuse) The lights flash to indicate the condition of the battery but in practice it tends to go red if the car isn’t used for a couple of day but there is plenty juice in the battery even if left for a month or so.
It’s a Ctek part so probably still available and makes it very easy to plug in the charger when I want.
Originally Posted by SER
CTEK do a 'comfort' connector with larger M8 eyelet connectors and in line fuse to connect direct to battery terminals. Cost around £7.50 on Amazon. Just fitted one works a treat.
Like you I used one of the Ctek comfort cables and fed it out to the nearside rear bumper bracket where I clamped the socket using a bracket that I made from Delrin. I find the hook up so simple and the socket has a rubber blanking plug to protect it when not in use
Owen
"bilibib"
1982 4/4 Twin Cam, Royal Ivory
1932 Super Sports, Duo tone(two tone)Green
Originally Posted by IvorMog
Can't remember which model my Ctec is but it came with 2 sets of cables, 1 with crocodile clips for direct to battery connection and 1 with a cigarette lighter plug.
Why not call Ctek and ask them for a solution.
As it happens I always use the cigarette lighter plug on Mog with no problems but I will use the crocodile clips to condition our Freelander's battery before we fire it up again.
Exactly the same, (ok,it’s the wife’s Evoque but very similar!)
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
I have 3 Cteks. IIRC each one came with a lead with crocodile clips, and another ‘cigarette’ lighter plug.
All are permanently connect to the cars. I was told to just leave them on ‘frost setting’, no problems so far...
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Rog Offline
Originally Posted by bilibib
What a clever solution and perfect for somebody like me with a failing memory thumbs
Roger
It's not that good for the forgetful, I have driven off with it still hooked up fortunately with no harm. But you have given me an idea, if put a longer lead on the Ctek I can do away with the alternator
Owen
"bilibib"
Page 3 of 3 1 2 3
