1 members (RedThree),
194
37
Topics49,911
Posts838,152
Posts: 425 |
Thanks for all your suggestions folks , much appreciated. I had wrongly assumed that my tatty box of ring terminals from Fleabay were the only ones available. I have now learnt otherwise. As you have suggested I will now change the ring connectors to a larger version and add a 15amp inline fuse.
John 2015 Plus 4 (GDI) Sport Green
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
I note that on two of my 3 chargers there is an inline fuse, I will add a fuse to the third.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
I just plug mine into the cigarette lighter socket, saves all this extra work and works a treat! Been doing it for years even got a plug in double socket for the lighter socket . I run the dash cam and sat nav from it
Posts: 185 |
When I got my car I found a little cable with a plug at the end with three LED’s, red, amber and green, I found out this was for plugging a Ctek charger into and is permanently connected to the battery (with fuse) The lights flash to indicate the condition of the battery but in practice it tends to go red if the car isn’t used for a couple of day but there is plenty juice in the battery even if left for a month or so. It’s a Ctek part so probably still available and makes it very easy to plug in the charger when I want.
Posts: 287 Likes: 8
Posts: 287 Likes: 8 |
CTEK do a 'comfort' connector with larger M8 eyelet connectors and in line fuse to connect direct to battery terminals. Cost around £7.50 on Amazon. Just fitted one works a treat. Like you I used one of the Ctek comfort cables and fed it out to the nearside rear bumper bracket where I clamped the socket using a bracket that I made from Delrin. I find the hook up so simple and the socket has a rubber blanking plug to protect it when not in use ![[Linked Image]](https://www.tm-img.com/images/2020/04/16/GEDC0020.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/04/16/GEDC0016.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/04/16/GEDC0017.jpg)
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Can't remember which model my Ctec is but it came with 2 sets of cables, 1 with crocodile clips for direct to battery connection and 1 with a cigarette lighter plug.
Why not call Ctek and ask them for a solution.
As it happens I always use the cigarette lighter plug on Mog with no problems but I will use the crocodile clips to condition our Freelander's battery before we fire it up again. Can't remember which model my Ctec is but it came with 2 sets of cables, 1 with crocodile clips for direct to battery connection and 1 with a cigarette lighter plug.
As it happens I always use the cigarette lighter plug on Mog with no problems but I will use the crocodile clips to condition our Freelander's battery before we fire it up again. Exactly the same, (ok,it’s the wife’s Evoque but very similar!)
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
I have 3 Cteks. IIRC each one came with a lead with crocodile clips, and another ‘cigarette’ lighter plug. All are permanently connect to the cars. I was told to just leave them on ‘frost setting’, no problems so far...
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 1,707 Likes: 36
Posts: 1,707 Likes: 36 |
What a clever solution and perfect for somebody like me with a failing memory
Roger 2011 Plus 4
Posts: 287 Likes: 8
What a clever solution and perfect for somebody like me with a failing memory  It's not that good for the forgetful, I have driven off with it still hooked up fortunately with no harm. But you have given me an idea, if put a longer lead on the Ctek I can do away with the alternator
