New
Topics48,365
Posts813,389
Members9,215
Posts: 6,061 Likes: 160
Posts: 6,061 Likes: 160 |
No front edge on mine (4 seat). There are also a couple of metal plates (going front to back) that join the planks together.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 5,056 Likes: 318
Posts: 5,056 Likes: 318 |
Culminator ..... in the pic there are two planks (the join is behind the rear seat frame ) . Joined by two straps held by two coach bolts (you can see the heads ) and two wood screws from underneath ..... it's held to the chassis by three bolts one either side and one at the back centre ..... the stainless steel bits are just me ....After 45 years the tank mounting had chafed into the wood near the four bolts that hold the tank in so I've made two plates for the tank to stand on ....you can see the nuts of the four bolts sitting there waiting for the tank fit ..... also a strengthening piece under the single rear bolt and penny washer under the side ones, again to stop chafing over time ..... the body frame is just tagged there as I final-fitted the bulkhead yesterday and want all the mastic to set with everything aligned ...tank will be fitted before the body is dropped on for the final time ....planks are bedded in mastic on the chassis. My car is a 4 seater but if the fundamentals are different in the 2 seater I'm sure someone will be along to put me right ![[Linked Image]](https://www.tm-img.com/images/2020/05/16/20200516_153544.jpg) K
Posts: 28,429 Likes: 180
Posts: 28,429 Likes: 180 |
Depends on the age of the car. Later ones the planks are on a frame that is bolted to the chassis.
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
Posts: 523 |
Thanks all, really useful info there and I think I now know what to do. That photo was really helpful Image. cheers Mike
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
My 79 +8 didn't have wooden planks, the tank was mounted on two z shaped steel brackets one direct to each chassis rail.
Posts: 1,415 |
Culminator ..... in the pic there are two planks (the join is behind the rear seat frame ) . Joined by two straps held by two coach bolts (you can see the heads ) and two wood screws from underneath ..... it's held to the chassis by three bolts one either side and one at the back centre ..... the stainless steel bits are just me ....After 45 years the tank mounting had chafed into the wood near the four bolts that hold the tank in so I've made two plates for the tank to stand on ....you can see the nuts of the four bolts sitting there waiting for the tank fit ..... also a strengthening piece under the single rear bolt and penny washer under the side ones, again to stop chafing over time ..... the body frame is just tagged there as I final-fitted the bulkhead yesterday and want all the mastic to set with everything aligned ...tank will be fitted before the body is dropped on for the final time ....planks are bedded in mastic on the chassis. My car is a 4 seater but if the fundamentals are different in the 2 seater I'm sure someone will be along to put me right ![[Linked Image]](https://www.tm-img.com/images/2020/05/16/20200516_153544.jpg) K You’ve bonded the boards in? How will you get the tank out if there’s a ever a problem with it? They come out from underneath I make a stainless steel frame that does away with the boards Simon@sifab.co.uk Sifabtemporary @gmail.com
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
On the 4 seater than can be removed from above easily. - remove the four fixing bolts and hoses and lift straight out (having done it twice in the last week or so  )
Posts: 523 |
Simon, does your "frame" bolt up from underneath? Can you share any pics?
Posts: 1,415 |
Simon, does your "frame" bolt up from underneath? Can you share any pics? Yes it does Most of the racers use them
Simon @ Sifab.co.uk
