7 members (RichardV6, Alan Patterson, Ian Wegg, JohnHarris, Laurens, GBpluseight, IcePack), 322 guests, and 40 robots.
+8Rich 95
John V6 49
Posts837,993
rockabilly john
Page 4 of 5 1 2 3 4 5
I’ve used engine paint on calipers for some years, works well and a fraction of the price.....
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Gone to Porsche
Gone to Porsche
Nothing wrong with that.
I was Gob Smacked today watching Classic Cars. Refurbished Calipers £750
Ouch
E
E
2006 Plus 4 Where you lead, I ..........
I like all the Front Disc Brake Caliper work, however, what colour do you then paint the rear drums?
Front red caliper's look epic, but would red rear drums (also in red look OTT?).
Can you up load some shots of the rear wheels (with the wheels on) so that i can see what red/black/silver etc. looks like "through the spokes of a road wheel" thumbs
Thanks
2004 Roadster S1 3.0 V6 gone!
Mark
E
E
My drums gloss black to match Calipers
Thanks
Ive kept my rear drums mat black, as existing
Craig Jezz
Online NoMood
Well also spurred on by Craigs brake caliper painting and armed with aerosol of Hycote red caliper paint and set of Morgan stickers I started the ball rolling yesterday. Car reversed into garage and on axle stands, so I can work with reasonable amouht of light.
Spent some time cleaning muck out of wheel arches and cleaning suspension. Removed pads and rubbed calipers down with 600 grit wet and dry both sides, although will leave portion on inside where mounting bolts are with OE finish. Surprised how well integrated with the black finish the Morgan logo is. I can still see it vaguely now although it shouldn't affect paint. Decided right or wrong to go for spray paint for best finish but underestimated the time and effort in masking everything up, committed now though. Presently about 80% through finishing one side. Cap head bolts that hold caliper halves together slightly rusty so they will get paint as well, not insides where pads locate though.
Cleaning everything in the area with help of powerful COB LED wand, I can now see what parts I missed with Hammerite silk black paint first time around, so they will get treated later. Whilst cleaning n/s wheel arch I heard a tinkling sound, turned out this was the washer under the large 1/2" UNF nut that holds inner wing (valance) tie bar in position, the one located behind and near top of radiator. It wasn't even finger tight and held only by underseal on threads! It locks against an inner nut to brace the valances which didn't seem to have moved, so nipped it up with a 19mm spanner. Wonder if this could have accounted for slight metallic rattle on that side over road bumps.
Another two or three days work at my leisurely pace but have plenty of time on my hands. Plan to lacquer over new stickers if paint test OK.
Online NoMood
Thanks
Best picture I have. At least the light is right to see my silk black Hammerite painted (for protection) drums.
Briefly thought to use red, but brake drums not something to be highlighted IMO.
Thanks
Agree - so I am going down the "paint it black" route. Thanks
Mark
Yep, black satin engine paint on mine, mainly because I had some on the shelf
I've also done the messy area between front hub & disc that MMC leave as untreated casting & it soon corrodes & looks nasty
