12 members (Ruut Bianchi, James B W, Hamwich, B3MOG, Saxman1964, Paulxj, MOG42, BobtheTrain, Jens, Ian Wegg, BHV, TalkMorgan), 232 guests, and 25 robots.
+8Rich 101
John V6 59
Topics49,912
Posts838,156
Georgetoad, woolfie
Page 9 of 21 1 2 7 8 9 10 11 20 21
I ordered from summit and it is taking a really long time. The good news is they are reputable and have all the parts.
2017 M3W Sport Green
Did you get hose from there? Part #?
Aka Joejoe
Originally Posted by Q8morgan
Hello guys
I hope all is doing well. I would like to order a complete new fuel pump kit and have it ready just in case i need it. I went through the alternative parts list.
But I can’t find all the parts on summit racing, ebay,amazon.
I just found:
- The walbro pump on summit racing.
- I can’t find/ figure out what else i need.
Can someone help me out with links or part numbers to complete the kit.
Many Thanks
-https://www.ebay.com/itm/Genuine-Walbro-GSS342-255LPH-Fuel-Pump-Fits-Honda-Civic-Del-Sol-1993-1997/173641447075
-https://www.ebay.com/itm/1x-In-Tank-Conveluted-Fuel-Injection-Hose-Plastic-210mm-PFH0825/233018085394
Are these all the parts i need?
Living in Kuwait I would order the full kit from Glencoe Ltd in the UK
www.glencoeltd.co.uk
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
Do you think a 220mm hose would work ok?
Bunny Offline OP
I don't see why a 220mm hose wouldn't work as long as it is flexible and has the same ID as the standard one.
Andy
What is the i.d. Of the standard one? 8mm?
I didn’t think being 10mm longer would be a problem but it doesn’t hurt to ask.
The hose I purchased was 71-54 or TF0001275. Hard to find descriptions on the hoses that are meaningful. I haven't installed it yet as I am still waiting for the pump but pretty sure it will fit.
Bunny Offline OP
I've just measured my spare and make it 7.6mm ID & 10mm OD.
Andy
I found “8mm I.d.” Hose but nothing lake 7.6mm
Bunny Offline OP
I'm guessing that it's designed to be a tight fit over an 8mm spiggot and it may even be a 'nominal' 8mm. In any case it's held in place by a clamp so I'm sure your 8mm ID pipe will be fine.
Andy
