9 members (sewin, Jon G4LJW, linklaw, nick w, MATTMOG, Mogdavid, High Hamster, Grumpy2, bmgermany), 192 guests, and 37 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,041
#642417 05/06/20 04:54 PM
Can any one help, I striped down all the car over 18 months ago to restore/ rebuild and can't work out the cooling pipes that come out from the front of the inlet manifold. The pipe which screws to the underside goes to the heater, but the outlet from the manifold that's the one has me scratching my head
Thanks
Gary, my Mog is and 85/6 with Stromberg carbs thus may be different, if you have a manual choke..? The area around the front of the manifold is a bit crowded though on my Mog it seems like there is a water circuit through the auto choke mechanism, which uses water temp to determine aspects of it`s operation..Hope this helps.
Mine has su carbs with manual choke. I took lots of pictures as the car was taken apart, but missed this area!! Grrrrrrr
Gary - I have a 1980 +8 I will photograph in the morning. Carbs, manual choke etc..... Send me a private message with your email address. You will have the pictures by lunchtime.
1980 +8 Blue
And a few others
Stephen
