3 members (Carbuilder, JoeSpeetjens, uvk33n), 297 guests, and 33 robots.
+8Rich 96
Luddite 54
Topics49,904
Posts838,083
Page 2 of 4 1 2 3 4
Originally Posted by Heinz
I am a little surprised about the height of your 4/4, Vassilis. I have exactly these four-seater leaf springs we're talking about. If you zoom in on my avatar, you can still see the car in high resolution. I have to check again if the garage has added extra blocks to get the car lower, but I'm pretty sure that this is not the case.
Others may know better but I can not imagine that the weight of the additional spare wheel has so much influence on the height.
Your car sits perfectly! I think the weight of the spare makes a difference.
2009 Morgan 4/4 Sport
I believe Mulfab do a centre-ing block which also lowers the rear end a little. A recent post referred to this but on older cars I think the petrol tank may need to be moved as well.
Other experts should be along soon with proper advice.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Try GoMog there is something in there on that and on the 4/4 Sports lowering blocks.
As I understand it, one should avoid the lowering blocks if possible in order not to worsen the handling.
I removed the lowering blocks on mine.
That reduced grounding a lot.
The spare wheel can not cause that much difference compared to co-pilot and a big suitcase on the rack which is standard on holiday trips. My car can handle the weight in the rear.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Originally Posted by VassilisP
Wow, it sits a lot higher than my 4/4
Craig Jezz
Mulfab advertise a centralising block of 3/8 inch, which will move axle back by 15mm and also a lowering block at 19mm, which will also lower it by 19mm. I think the first step Vassilis would be to have a look at your axle to see if there are any existing blocks between the top leaf of the spring and the axle. Whilst there, count how many leaves are on your current springs to determine whether a change from standard has already been made.
Doug
1958 Triton 650
That explains it, I have these lowering blocks on my 4/4 which I believe was a standard fit at the factory from approx 2012 onwards ? Dave W would know.
You can just see them here if you zoom in
Craig Jezz
Yes they were a standard fit.
In the case my car also should have this lowering blocks, is it easy to remove them just for a test of looks and drivability?
Page 2 of 4 1 2 3 4
