Posts837,978
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
[quote=Dee Useful tip: when using a hole saw, run it in reverse for a few turns to gently scratch into the veneer before cutting, to avoid splitting and chipping. I also found that the hole was slightly tight and opened it out using an abrasive flap wheel on the drill. That’s a great tip! Cheers Doug.[/quote] Good advice running backwards for the initial 'cut' I also put masking tape around the circumference of the dash face & sometimes gently take the outer tip of the hole saw teeth off on a bench grinder as some have an aggressive tooth shape, then drill a test hole in a piece of scrap plywood
Posts: 1,236 Likes: 40
Posts: 1,236 Likes: 40 |
Andy, the rev counter is in the centre, I must have taken the photos centered on the gap between the rev counter and clock. You had my OCD head worried there for a moment
Gordon Duguid 2014 Duratec engine plus 4, Montreal blue.
Posts: 128 |
Hi, I have just measured the distance on my car and it is 34mm between the RC & Clock. --------------------------- John 2011 Plus 4 (Marty)
Posts: 902 |
Thanks to all for the information & tips.
It doesn't seem there is a standard measurement and I think I will choose whats best for my seating and steering wheel position level with the other gauges.
Rob
Posts: 979 Likes: 2
Posts: 979 Likes: 2 |
Rob, I must admit I never, look at the clock in Seve'......time in the Morgan is precious, therefore not concerned. However, post an image when done
2004 Roadster S1 3.0 V6 gone!
Mark
Posts: 902 |
Rob, I must admit I never, look at the clock in Seve'......time in the Morgan is precious, therefore not concerned. However, post an image when done  Hi Mark I take you point but I keep looking at the empty space thinking something is missing! The clock wiring is there and I think they look good and I like spending money on my Morgan. Will add photos when I can get hold of a clock!
Rob
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Rob, I must admit I never, look at the clock in Seve'......time in the Morgan is precious, therefore not concerned. However, post an image when done  Hi Mark I take you point but I keep looking at the empty space thinking something is missing! The clock wiring is there and I think they look good and I like spending money on my Morgan. Will add photos when I can get hold of a clock! Think I’m going to fit mine here Rob, then again I might change my mind tomorrow  ![[Linked Image]](https://www.tm-img.com/images/2020/06/14/F95F12DF-0338-47F6-9547-C88C0F927695.jpg)
Craig Jezz
Posts: 902 |
It looks to me like thats 165mm to dial centres Craig
Rob
Craig, what's the manual pull choke knob for, at the side of the glovebox ??
Craig, what's the manual pull choke knob for, at the side of the glovebox ?? I fitted a manual choke conversion...............only joking its my magnetic mobile phone holder
Craig Jezz
