5 members (DCH, TigerTim, Haggispeed, Lionel Mandrake, TBM), 320 guests, and 42 robots.
+8Rich 95
John V6 52
Posts838,013
rockabilly john
After reading about these headrests I felt I too needed a pair.
Contacted Allon White and just received them. AW took the time to: have me send them a lot of pictures of my current seats, contacted Morgan to make sure the leather, stitching pattern, and the color of the inset stitching(silver) itself would be a perfect match. They even sent the final product with a few extra connector pins just in case. Took 2 minutes to install.
Superb craftsmanship and excellent quality. Could not be happier. Thank you Julie & John!
2018 S&S 110th Beetleback
1934 MX4 Beetleback (in restoration)
1965 Corvette Coupe 327/350
Dutch Offline OP
Yes quality is top notch. They are very easy to deal with. Fit is perfect.
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
Could you please post some photos ? Thanks.
92 Connaught Green Plus 4
Triumph Bonneville 865
Next weeks I will have my own headrests done by my upholsterer. They need to be specifically done for my 3W as the Allon White’s won’t work, because of the new model luggage rack supports. The idea is quite simple too, but with only one single strap & buckle in the back, avoiding it to move by this strap and a different shape, similar to a champagne cork as it will “fill” the inside of the roll hoops. I will post pictures while they will be finished.
www.speedymarmots.com
Job finished!
Check the new post in our blog for details https://www.speedymarmots.com/hangar-works-20-headrests-pads/
Very nicely done Javier. Looks like they came from the factory.
Scott
2018 M3W
1995 Porsche 993
Nice job Javier.
Just for the record, Allon White can make headrest pads to suit the 2018 luggage rack. You just need to let them know when you order and they will relieve the back board to clear. I ordered without but they kindly adjusted them for me whilst I waited. Had a good look around the trim shop at some of the other projects they had on at the time. Very helpful and friendly team that I would have no issue recommending.
Originally Posted by PhilV
Nice job Javier.
Hello Phil! Yes I know they adapt the pads to the new luggage supports too. If I was in the Uk i would have contacted them. But being here in Spain, quite isolated from the Morgan World, I decided to go to my upholsterer. So, I was sure at 100% that the leather color will match and I also prefer our "champagne cork" and simple strap and buckle design rather than the three "lift-the-dot" straps that Allon White offers.
