2 members (sewin, Tony Quinn), 262 guests, and 53 robots.
+8Rich 90
Luddite 50
Posts837,962
Page 2 of 5 1 2 3 4 5
Originally Posted by Themorganeer
[quote=Dee
Useful tip: when using a hole saw, run it in reverse for a few turns to gently scratch into the veneer before cutting, to avoid splitting and chipping. I also found that the hole was slightly tight and opened it out using an abrasive flap wheel on the drill.
That’s a great tip! Cheers Doug.[/quote]
Good advice running backwards for the initial 'cut' I also put masking tape around the circumference of the dash face & sometimes gently take the outer tip of the hole saw teeth off on a bench grinder as some have an aggressive tooth shape, then drill a test hole in a piece of scrap plywood
Andy, the rev counter is in the centre, I must have taken the photos centered on the gap between the rev counter and clock. You had my OCD head worried there for a moment crazy2
Gordon Duguid
Hi, I have just measured the distance on my car and it is 34mm between the RC & Clock.
2011 Plus 4 (Marty)
RobCol Offline OP
Thanks to all for the information & tips.
It doesn't seem there is a standard measurement and I think I will choose whats best for my seating and steering wheel position level with the other gauges.
Rob
Rob, I must admit I never, look at the clock in Seve'......time in the Morgan is precious, therefore not concerned. However, post an image when done thumbs
2004 Roadster S1 3.0 V6 gone!
Mark
RobCol Offline OP
Hi Mark
I take you point but I keep looking at the empty space thinking something is missing! The clock wiring is there and I think they look good and I like spending money on my Morgan.
Will add photos when I can get hold of a clock!
Rob
Hi Mark
Think I’m going to fit mine here Rob, then again I might change my mind tomorrow
banghead
Craig Jezz
RobCol Offline OP
It looks to me like thats 165mm to dial centres Craig sherlock
Rob
Originally Posted by Craig Jezz
Craig, what's the manual pull choke knob for, at the side of the glovebox ??
I fitted a manual choke conversion...............only joking its my magnetic mobile phone holder
Craig Jezz
