Topics49,904
Posts838,081
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
Went to Caister Castle car museum with the Great Escape Gang. Great fun even if it rained a lot.
Posts: 8,701 Likes: 501
Posts: 8,701 Likes: 501 |
Stripped the front hubs to check the bearings were set up & lubed correctly, so of course you have to follow it up with a test run  ![[Linked Image]](https://www.tm-img.com/images/2020/07/10/David-Mellors-3.jpg)
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
SFG 2012 4/4 Sport
Posts: 37,481 Likes: 989
Posts: 37,481 Likes: 989 |
Stripped the front hubs to check the bearings were set up & lubed correctly, so of course you have to follow it up with a test run  ![[Linked Image]](https://www.tm-img.com/images/2020/07/10/David-Mellors-3.jpg) Your car looks splendid Jon, where is that interesting looking building ?
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Went for the MOT today, it didn’t pass & it didn’t fail.......I was told its booked in for the following Friday  ![[Linked Image]](https://www.tm-img.com/images/2020/07/10/0E9A381B-6E2F-4D58-962F-53CC0B8DB1D4.jpg)
Craig Jezz
Posts: 902 |
Went for the MOT today, it didn’t pass & it didn’t fail.......I was told its booked in for the following Friday An extreme case of setting off early, better luck next week!
Rob
Posts: 2,120 Likes: 71
Posts: 2,120 Likes: 71 |
Went for the MOT today, it didn’t pass & it didn’t fail.......I was told its booked in for the following Friday An extreme case of setting off early, better luck next week! Did you need a reason for a trip with your 4/4?
Posts: 82 |
The Round Building, Leadmill, Hathersage. Nice coffee
It seems to be a cutlery factory Round building
Thanks John, I like that building a lot.
