Topics48,337
Posts812,917
Members9,203
Posts: 7,916 Likes: 216
Posts: 7,916 Likes: 216 |
Not sure if it makes or breaks the circuit when seat belt buckle clicked, but either way it could be simulated by unplugging and/or adding link if needed.
Posts: 469 |
go to a local scrapyard and get the seat belt buckle, cut the strap off and put the buckle in.
2017 Mercedes Benz SLC 200 AMG. 2019 Mercedes Benz GLA 200 AMG Now Ex-Mogger!
Posts: 7,892 Likes: 241
Posts: 7,892 Likes: 241 |
On the later Roadsters with seat belt buzzer, it was just a matter of disconnecting the harness plug under the seat
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
Will it be so easy to disable it on a new plus four which uses a bus for wiring? It could be but equally it may not be so simple I know you can’t change things like the lights without upsetting things.
Will it be so easy to disable it on a new plus four which uses a bus for wiring? It could be but equally it may not be so simple I know you can’t change things like the lights without upsetting things. No reason to assume it still cannot be overriden Gary. The belt clip sensor is a simple switch and very easy to simulate, so it won't upset the BCU. With lights (if MMC haven't disabled in firmware) its a different matter as they sense current flow to determine if bulb blown.
Posts: 697 Likes: 7
Thanks Richard. If I get a new plus four disabling the seatbelt will be my first change to the car
Pop it round to mine & I'll sort it, no issue with the Roadster BCU, then you can take me out for a PlusFour blast
Posts: 26,747 Likes: 419
Posts: 26,747 Likes: 419 |
The Great Escape Gang seem to be upgrading cars. Tony moving to a Brooklands Roadster & Gary in love with the Plus Four. Soon Nick plus four & i will have the least powerful cars.
Posts: 6,723 Likes: 2
Posts: 6,723 Likes: 2 |
Posts: 956 Likes: 1
Posts: 956 Likes: 1 |
How does disabling a safety feature impact (pardon the pun) on any insurance claim?
2004 Roadster S1 3.0 V6 gone!
Mark
