10 members (Willowgreen320, Hamwich, Alan Patterson, MATTMOG, sewin, RobS, Rog, High Hamster, stumog, Morganmike), 251 guests, and 52 robots.
+8Rich 91
Luddite 50
Posts837,969
#652741 27/07/20 10:57 AM
Max5 Offline OP
The handbook for my new 3.7 Roadster has no information on the operation of the heated seats. There seem to be three positions on each of the switches. Can anyone provide information on the purpose of each swirch position Thanks in anticipation.
Don
Formerly known as Aldermog
If it is the same as our Plus 8, which is likely, then the mid position is off, the upper is hot, with a red led and the bottom position is green, with warm heating.
Max5 Offline OP
Sounds as if it is the same, thanks Peter.
That is how the aftermarket ones from Allon White work.
That’s how the ones I fitted work too. Highly recommended retro fit!
This what it is on the Factory fitted ones I have on my 4/4.
Our one works in a slightly different way in that the middle is off, up is seat and back and down is seat only or it could be the other way around. And they get very hot, these were factory fitted.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
