3 members (John V6, Bunny, Mike D),
264
32
Posts837,998
Posts: 14,009 |
Following on from Davids posting re Wolgangs car, I've now fitted the Chronos clock to the dash of my 4/4 Sport
Definitely Old School Learner Plates Off!
Posts: 481 |
What a perfect fit!!! Lifts the whole dash which already looked good----stunning addition, well done you.Best regards D
David of SW19
Posts: 921 Likes: 1
Posts: 921 Likes: 1 |
Jay, that is a nice addition.
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
Is there a cream faced option?
Ah just checked. not with a chrome bezel by the look of it.......
Posts: 220 |
Beautiful - excellent work. If it has a small button cell compartment at the back (and you had nothing better to do), you might be able to slip in a couple of really thin wires and a miniature LED for night-time illumination as I think you will find a 12v supply behind the dash hole if it's anything like my Plus8. But certainly it is fine as is - well done.
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
Is it luminous at night??
Posts: 3,727 |
A very nice looking clock Jays  . Looking at Pic 2 side view, It appears to be surface fitted? How is it actually attached?
Posts: 14,009 |
Not tested it at night yet Robbie but I don't think so.
Frank ... I was going to use double sided tape but as its so nicely made I've decided to make it a permanent fitting. The clock outer casing into which the clock fits has a hole in the base for screw fixing, which is what I've done.
I've just joined the Clock Club. I see there's a 'Boshers' in the address. Thanks to Robbie I found the cream version with chrome bezel. Now look what you've started Jays............
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
A decent clock should be standard kit on a Mog, more use than a rev counter, all that's good for is calculating the speedo inaccuracy
