5 members (Carbuilder, Davetherave, RichardV6, IcePack, bmgermany), 256 guests, and 40 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,043
#65473 28/07/11 12:39 PM
Hi all, anyone know where I can get the white racing number roundels from that go on the doors and or bonnet. I assume that they can be obtained in vinyl decal form as opposed to having them painted on. Cheers Steve.
smiffmog #65475 28/07/11 01:25 PM
NGUNS!!
NGUNS!!
http://www.hollographics.com/acatalog/Door_Numbers.html
Used them before and very helpful.
HTH
smile
Cheers
BtG
Boshly #65481 28/07/11 03:03 PM
demon tweeks
grand prix racewear
Merlin motorsport
Fixing broken sh1t
smiffmog #65527 29/07/11 08:11 AM
M3W Offline
Great idea, the quickest and cheapest way to adapt racing image to your car. drive
Spend a little extra time in preparation - to find both the right size and position. If wrong it just looks strange and unbalanced.
I buy the vinyl (or whatever it is) in a roll from a sign maker and use a compass with a scalpell blade attached to it. Matt vinyl looks better than glossy. Use a "flower sprayer and a rubber scraper" when positioning.
On the sides: if positioned slightly closer to the front wheel than rear the car looks faster (depending on the design of the car). On the bonnet/rear: do not place it directly in the middle, offset positioning looks better (think racing track, very few spectators watching from above car). Very double curvatured surfaces are tricky to cover, the material is possible to stretch a little or just cut it (from he center and out).
Clean the surface before applying the roundel to make sure no dirt lifts the vinyl, wax the car before. Afterwards be careful with water pressure directly to the edges when washing. If leaving it on for ages...it might be hard to remove in one piece - sunlight and age makes it brittle with time.
More than three roundells/car looks often to much...
If you also are going for a number, be careful to find a font, size and number to match your car.
I once had a question from a girl if the white spots on my car was to make it look like a ladybird...
Happy racing!
smiffmog #65689 01/08/11 12:02 PM
Cheers Guys, thanks the pointer's, I'll post the results.
Regards
