Topics49,918
Posts838,238
Posts: 5,017 Likes: 3
Posts: 5,017 Likes: 3 |
Yesterday evening my 4/4 refused to start. After I inserted the key the standard procedure of speedometer needle jump worked, klicking of engine valve preset was there but no reaction from the starter when I turned the key in starting position. Key out, re-inserting, same problem. After knocking hard at the steering column starting was ok.
This morning: no starting at all. Both Starter keys were tested with the same result. On purpose I did no knocking the steering column trick.
I had a similar problem last season, brought the car to my Morgan dealer and the transponder ring got re-located (at least I think they did that for solving the problem)
The car is safe in the garage. Any advise from the professionals if I could do the fixing of transponder ring myself? Is there a risk to damage something? Spare part supply from MMC seems to be slow at the moment.
Posts: 37,492 Likes: 994
Posts: 37,492 Likes: 994 |
I've not had this myself Hannes but others have, I know DaveW has a thread on here somewhere as his car suffered from it and the ring needing moving a little I seem to recall.
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi Hanes,
My 2006 car was a bit of a mess, whole cowl fitting and transponder ring fitted by a butcher.
A thick cable tie had been fitted to stop the ring sliding down but nothing to stop it rotating and moving, absolutely awful.
Solution for me was double sided tape. Easy job, just ensure you place the ring so that the cowl refits properly.
Best of luck
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 2,125 Likes: 37
Posts: 2,125 Likes: 37 |
I've not had this myself Hannes but others have, I know DaveW has a thread on here somewhere as his car suffered from it and the ring needing moving a little I seem to recall. Here's DaveW's thread. http://www.talkmorgan.com/ubbthreads.php/topics/539514/1
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
Hi folks! Thank you for comments and special thanks for the link to the other thread. I'll try the 20 seconds game!
I assume the immobilizer is an integral part of the Morgan electric setup. Otherwise I would prefer to remove it and have no immobilizer. Murphy's law applies to Morgan cars as far as I have experienced. What is not there can't make problems so no immobilizer would be OK. (I think Murphy's car was a M3W)
I'd definitely be exploring a workaround it can't be too difficult.
Posts: 383 Likes: 6
Interesting thread of DaveW.
Interesting that his car had neoprene to stop the ring falling inwards. My car only had a cable tie, with the side of the cowl to keep in place.....the poverty solution.
Best of luck with an alternative solution, Hannes
Regards
Thank you - I may need luck. The 20 seconds key contact does not work on my car, even with removed cover. I will call my Mog-dealer tomorrow. Hopefully no need to transport the car to his garage.
My key transponder system does look different than the one in DaveW's thread. It is a Ford origin spare part ![[Linked Image]](https://up.picr.de/39194763tl.jpeg) ![[Linked Image]](https://up.picr.de/39194764cp.jpeg) This is the setup on DaveW's car pic copied for ease of comparison (no copyright violation - I hope) ![[Linked Image]](https://up.picr.de/39194814if.jpeg)
