3 members (+8Rich, MartinB60, linklaw), 200 guests, and 58 robots.
+8Rich 84
Luddite 50
Posts837,947
#651888 22/07/20 12:39 AM
kankeL Offline OP
Hello folks,
It seems that the input shaft seal on my bevelbox is leaking. Has anyone replaced it yet?
Would appreciate any advice and some part numbers?
Thanks!
kankeL #651892 22/07/20 01:06 AM
There is a good write up about it in the MTWC Bulletin if I recall correctly. There was also a Thread here somewhere talking about it.
kankeL #651917 22/07/20 07:30 AM
I have replaced mine, fairly straightforward full instructions and part numbers can be found on the MTWC website, just remember the pinion nut is LH thread .
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
kankeL #655098 09/08/20 11:19 AM
Replaced the pinion seal yesterday, no drips overnight. Taking her out this morning to see if the problem is solved.
Modified the drive shaft hoops so that now I can unbolt them and bolt them back in. Should have been designed that way in the first place instead of being welded in.
Lance
1981 Plus 8
2016 Three Wheeler
2022 Corvette Stingray Convertible z51
kankeL #655100 09/08/20 11:20 AM
KankeL, Have you replaced your seal yet?
Lance
1981 Plus 8
2016 Three Wheeler
kankeL #655114 09/08/20 12:32 PM
How long did it take you to replace the seal on your own?
Is it a matter of hours or do you need a couple of days? Is it "easy" or the kind of screaming in pain job because you hammer your fingers scared and suffering many other physical injuries while doing it?
www.speedymarmots.com
kankeL #655119 09/08/20 01:46 PM
Removing the bb is not terrible. Slacken the drive belt. Remove seatback, remove drive shaft cover, mark drive shaft to bb flange so you can get them back together in the same orientation. Unbolt bb and wiggle it away from belt and car.
Opening up the bb after you have drained it is easy. Remove bolts and use two large flat screwdrivers to pop off the side plate and pinion gear. If yours is older i would be tempted to have a new gasket ready to replace the old one.
From that point on i have not taken out the shaft seal. Refer to the MTWC instructions.
Lance #655139 09/08/20 03:23 PM
kankeL Offline OP
Just got the seal. Any chance you can take a picture of your modified hoops? What did you use to hold the carrier plate in place? Do you remember the size of the retaining nut? Any particular torque spec? Would appreciate any further advice:-)
Marmota #655208 09/08/20 09:57 PM
To replace the input shaft seal is not a big job Marmota but will take 2 or 3 hours to gain access, drain the BB, do the seal change, fill the BB with oil and put everything back. You do need to plan the job as it requires a few special tools, the gag to hold the flange and some large sockets for the shaft nut and to push the new seal in with. You could do this in your apartments underground parking area but, like most jobs, it would be much easier in a well equipped workshop. No fingers should be lost laugh2 .
Originally Posted by planenut
You could do this in your apartments underground parking area.
OR on your kitchen table... innocent
Andy
