6 members (JMcL, RichardV6, CooperMan, Paul F, James B W, Ritchie B), 330 guests, and 47 robots.
+8Rich 103
John V6 63
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,242
MossyfromNZ
Page 1 of 4 1 2 3 4
#655087 09/08/20 10:46 AM
Yesterday evening my 4/4 refused to start.
After I inserted the key the standard procedure of speedometer needle jump worked, klicking of engine valve preset was there but no reaction from the starter when I turned the key in starting position. Key out, re-inserting, same problem.
After knocking hard at the steering column starting was ok.
This morning: no starting at all. Both Starter keys were tested with the same result. On purpose I did no knocking the steering column trick.
I had a similar problem last season, brought the car to my Morgan dealer and the transponder ring got re-located (at least I think they did that for solving the problem)
The car is safe in the garage.
Any advise from the professionals if I could do the fixing of transponder ring myself?
Is there a risk to damage something? Spare part supply from MMC seems to be slow at the moment.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
I've not had this myself Hannes but others have, I know DaveW has a thread on here somewhere as his car suffered from it and the ring needing moving a little I seem to recall.
Hi Hanes,
My 2006 car was a bit of a mess, whole cowl fitting and transponder ring fitted by a butcher.
A thick cable tie had been fitted to stop the ring sliding down but nothing to stop it rotating and moving, absolutely awful.
Solution for me was double sided tape. Easy job, just ensure you place the ring so that the cowl refits properly.
Best of luck
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Here's DaveW's thread.
http://www.talkmorgan.com/ubbthreads.php/topics/539514/1
Regards
Alan
AP08 MOG
Hi folks!
Thank you for comments and special thanks for the link to the other thread.
I'll try the 20 seconds game!
Hannes
I assume the immobilizer is an integral part of the Morgan electric setup.
Otherwise I would prefer to remove it and have no immobilizer.
Murphy's law applies to Morgan cars as far as I have experienced.
What is not there can't make problems so no immobilizer would be OK.
(I think Murphy's car was a M3W) oops
Hannes
I'd definitely be exploring a workaround it can't be too difficult.
Interesting thread of DaveW.
Interesting that his car had neoprene to stop the ring falling inwards.
My car only had a cable tie, with the side of the cowl to keep in place.....the poverty solution.
Best of luck with an alternative solution, Hannes
Regards
Geof
Thank you - I may need luck.
The 20 seconds key contact does not work on my car, even with removed cover.
I will call my Mog-dealer tomorrow. Hopefully no need to transport the car to his garage.
Hannes
My key transponder system does look different than the one in DaveW's thread. It is a Ford origin spare part
This is the setup on DaveW's car
pic copied for ease of comparison
(no copyright violation - I hope)
Hannes
Page 1 of 4 1 2 3 4
