11 members (bmgermany, MOG42, Strathaven, Clipper, JoeSpeetjens, gomog, MJF, RichardV6, John Winn, SailingTom2, uvk33n), 272 guests, and 29 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,146
So my car has an annoying squeak I have traced to rubbing where the base of the grille rests on the body. The protective tape installed by Morgan in this area had long-since worn though before I got the car. Some of the paint has also worn through.
What are other owners using as padding or protective covering in this area? I would love to see some pictures of solutions. Or a description of materials used to fix this problem.
I use a piece of 3 mm thick neoprene of the appropriate shape glued to the body.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I have some 3mm thick rubber matt, trimmed to shape under the front edges of the grill cowl, to act as a pad between the cowl and body. It can be stuck in place with Super Glue. The bonnet Dzus fastener springs get bent inwards and weaken their grip over time. If you use a small screwdiver to carefully bend them back out it will put some more tension on them. This will help stop the bonnet moving about, squeaking and wearing the paint finish. The 3M protective tape is easy to replace as well and will help save the paint finish.
I replaced the clear tape then glued felt to the bottom of the grille shell to allow relatively friction free movement. Though it was better than trying to stop all movement in that area which seems unlikely with the factory arrangement.
Later I split my bonnet down the middle and bolted the grille shell solid, but that's another story.
Late 2012 M3W
Good luck on keeping anything glued in there.I have been thinking about bolting in a bit of rubber.
Replaced mine last week with some nice leather from an old belt. Cut to shape and glued with contact adhesive.
Super Glue and rubber usually work well together, almost as good as sticking fingers together laugh2 .
I have tried some pretty high tech adhesives to no avail.
Has anyone investigated casting rubber around a bolt?
My 2012 version came with a complimentary hole in this area, so when the stuff came off the cowl I put rubber grommets in.
These help keep the cowl off the paint (no 3m tape)
I also glued a shaped piece of chamois leather on the cowel.
Has worked well for several years now
Ha! Good idea, I have the holes as well but never thought of a grommet. Thanks for the tip.
