6 members (nestor59310, Ruut Bianchi, MATTMOG, Supermog, BLUE+4, GrumpyPa), 232 guests, and 42 robots.
+8Rich 101
John V6 59
Topics49,912
Posts838,160
Georgetoad, woolfie
Page 1 of 4 1 2 3 4
E
E
Hi to all
My car is a 2006 Plus 4
I am sure this has been addressed and perhaps all I need is pointing to the relevant thread.
I want to convert my standard Morgan bullet wing mounted side lights to MOT compliant DLRL LEDs
I believe that the standard bullet light bulb can be converted to (I think) a six ish LED cluster bulb.
I also know that the existing live wire will need to be connected to an appropriate ignition on permanent live.
However, to be MOT compliant I want to ensure the DLRL are dimmed when the main/dipped beam is manually switch on. So I am assuming there is a gizmo/relay that senses/knows when power is going to main/dipped beam and consequently reduces voltage to DLRL bulbs.
So is there anybody that can provide
a. Part number source for the two DLRL LED bulbs that are appropriate for existing bullet housing/bulb holder.
b. The part Number of gizmo/relay to dim DLRL when main/dipped beam on
c. Wiring diagram and Recommended take-off points for ignition on permanent live for LEDs and the connection map for the relay/gizmo with best take-off/fitment location.
All help really appreciated
Regards
Ian
I think Car builder solutions sell a relay kit.
I simply opted for the 1/2 moon LED lights in the headlamp and the lights are wired to come on with the ignition. As the aren't DLR lights there is no MOT issue.
I also replaced the sidelight bulbs with LED of the same token wattage.
If you don't want the expense of buying the CBS kit, you can just use a standard 30 amp, 5 pin diode relay. Wire the relay coil to dipped beam supply (pin 86 +, 85 -). Take an ignition feed to the relay main contact (30) and on to DRL's such that when coil is de-energised the DRL's are on with ignition (pin 87a) but as soon as dipped beam selected they are extinguished.
Given that you are just replacing wing mount bulbs (which are on with headlamps as OE) the LED replacements although brighter may still qualify as side/position lights so possibly no need for above.
E
E
Hi,
First thanks to those who responded.
I also found this kit on ebay. link. Also see cut and paste product description below.
Any views?
Also can anybody give me a link to a plug and play replacement bright LED bulb to fit in the wing bullet housing
https://www.ebay.co.uk/i/3241424607...8x6-n6wIVj-vtCh2rZQ_vEAQYHSABEgK3YPD_BwE
Product Description
Description:
DRL Controller Car Auto LED Daytime Running Light Relay Harness Dimmer On/Off 12-18V Fog Light Controller
Features:
- Mini shape, light weight and waterproof
- Time-lapse power off function
- Simple installation, with no need to change any electric line
- Intelligent start up: when the engine is started, the daytime running lights light automatically. when the engine is turned off, the daytime running lights turns off with the delay of 15s
- Fit for all Brand of cars
Specifications:
Colour: Black
Material: ABS
Voltage: 12-18V
Working current: 5A
Power off delay time: 15 seconds
Product size: 39 x 21 x 17mm/1.54 x 0.83 x 0.67"
Wiring Instructions:
1. The red and black wire (the end with a fuse) are connected directly to the car battery + & - .
2. The red wire goes to positive pole of the LED daytime running lights, the black wire of the output end is to goes to the negative pole of the daytime running lights.
3. The white wire is to connect to the headlights (or dashboard lights), when headlights or dashboard lights are turned on, the brightness of the LED daytime running lights will be halved.
Included:
1 X DRL Controller
I've always used the ref 233 for the wingtop bulbs, you should be able to find an LED version of that
Check out these guys they may have what you’re looking for https://www.bettercarlighting.co.uk/index.php
Dave
98 +8 Corsa Red
74 MGB Red
Originally Posted by Eurosystem0
Hi to all
Ian
Your comments surprise me. All you are going is using your side lights as a sort of DLRL, and you are allowed to run with sidelights on all the time anyway. I am sure there is no requirement for sidelights to dim when the headlights are on. As I understand it, the only difference with DLRL is that on modern cars they are designed in such a way that they cant be switched off. That rule doesnt affect you or you would have a car fitted with DLRL anyway.
You may enjoy / want the added complication of dimming as a bit of tinkering / a project, but IMO you dont need to do it for MoT purposes. Bestc check, or if you have already checked tell me I am talking nonsense. laugh
E
E
Hi to all
Ian
I was told that if you are using the high intensity LED as DRL (as per new cars) they must dim when you put your head lights on. Its NOT just about having permanent side lights on.
I also have a friend who has converted his bullet lights to bright LEDs (without auto dimmer) and he is being flashed by on coming cars at night time. He is now trying to modify to dim (to half intensity) when headlights on..
The bulbs he used required a modification to bulb holder/bracket - which I am trying to avoid. Hence trying to locate a bright DRL LED bulb that fits existing bulb holder within bullet housing. Needless to say the LEDs need to be forward facing.
I am positive that with high intensity DRL they must dim to be MOT compliant.
Just found this on Govt web site:https://www.gov.uk/government/publications/daytime-running-lights/daytime-running-lights
Legislation and requirements:
Vehicle manufacturers must fit DRL to new types of passenger car and light goods vehicle (car derived vans) type approved to European vehicle requirements from February 20111 . In practice this means that any new model launched after this date, and many launched before, will be fitted with DRL. However, existing models on sale before this date without DRL fitted can continue to be sold and used indefinitely.
Similar requirements apply to large vehicles (such as HGVs) and buses from 7 August 2012. Motorcycles do not currently require DRL to be fitted, but most manufacturers voluntarily opt for an AHO (Automatic Headlight On) system to be installed as an alternative. Changes to European legislation will, in future permit manufacturers to fit DRL on their motorcycles.
DRL activate automatically when the engine is started and remain on unless the headlamps are switched on. They may however remain off in some low speed and stationary situations. In general all other lights should remain off when the DRL are on but for a limited period some vehicles may be available which automatically activate the rear position lamps at the same time as the DRL.
DRL may be combined with other lamps. For example some manufacturers use the same lamp for both the DRL and position lamp. In these cases the DRL automatically dims to function as a lower intensity position lamp when the headlamps are turned on. DRL placed close to direction indicators may also automatically dim when the direction indicator is active. This is to ensure that the direction indicator is not masked by the light from the DRL.
E
E
Hi All
My thread appears to have died so I will reduce the questions to just the one.
Can anybody identify a high intensity DRL LED bulb that will replace the existing 233 in the wing bullet lights without modification to bulb holder lens etc.
CBS do not appear to have one where the LEDs all face forward.
Regards
Ian
Ian,
Have you tried this place, they seem to have some 233 lights. https://www.classiccarleds.co.uk/search?q=233
Cheers
Page 1 of 4 1 2 3 4
