Morgan Aero 8
6 members (John V6, +8Rich, LE52MOG, IcePack, Hamwich, sprinty), 201 guests, and 35 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,092
#658600 26/08/20 02:15 PM
taffy Offline OP
Hi all
My car has failed the MOT as the Hand Brake is not holding sufficiently and the garage have said it needs new brake pads. Its not a Morgan garage- and so they are having difficulty identifying where these pads are from?
Thanks
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
Hi Taffy. Up to the series 3 if you have no adgustement or slack left the cams on the brake calipers will need to be adjusted, not sure if the ss has shoes inside. mine were like new but the bra.ke is really awfull. After re assembly it just passed the mot but is back to normal again annoying.
Cancel the above I think you have the twin caliper set up. Sorry.
le Asbo du Bling
le Asbo du Bling
Just looked at my series 5 and they are Brembo seem to recall it being the same on the S4 as well
Slowly going green
taffy Offline OP
Thanks Aerotaff!
Asbo John - so are they from a BMW model then?
Thanks
15 Weissman GT5
11 Aero8 SS
21 Q7
23 RR
24 Def'r 130
1960 XK150 DHC
1970 E-type
2024 Huracan Tech
The Morgan part number is mbso6670 Brembo might have a cross reference.
Em
