Topics49,908
Posts838,116
Posts: 378 |
Hi all My car has failed the MOT as the Hand Brake is not holding sufficiently and the garage have said it needs new brake pads. Its not a Morgan garage- and so they are having difficulty identifying where these pads are from? Thanks T
15 Weissman GT5 11 Aero8 SS 21 Q7 23 RR 24 Def'r 130 1960 XK150 DHC 1970 E-type 2024 Huracan Tech
Posts: 2,439 Likes: 71
Posts: 2,439 Likes: 71 |
Hi Taffy. Up to the series 3 if you have no adgustement or slack left the cams on the brake calipers will need to be adjusted, not sure if the ss has shoes inside. mine were like new but the bra.ke is really awfull. After re assembly it just passed the mot but is back to normal again annoying.
Cancel the above I think you have the twin caliper set up. Sorry.
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
Just looked at my series 5 and they are Brembo seem to recall it being the same on the S4 as well
Slowly going green
Posts: 378 |
Thanks Aerotaff! Asbo John - so are they from a BMW model then? Thanks T
The Morgan part number is mbso6670 Brembo might have a cross reference. Em
