Posts837,990
Posts: 367 Likes: 12
Posts: 367 Likes: 12 |
This was in a Pinterest email I received. Does anyone know more about it? ![[Linked Image]](https://www.tm-img.com/images/2020/09/23/b54a56912191b40d18ff97c7769c69e5.jpg)
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Looks nice, great for "social distancing" and for tall people seeing over the engine would be a good thing, but it does look good.
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
To me some of the angles, shading & highlights aren't quite right, I suspect it only exists as CAD
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Engine somehow reminds me of side valve V twin used in small aircraft tow tractors, maybe JAP??
To me some of the angles, shading & highlights aren't quite right, I suspect it only exists as CAD Many hours of Photoshop. Look at the position of the crank as compared to the belly of the vehicle, it would make for an interesting driveline. Unless it is front wheel drive.
Posts: 1,075 |
Early Harley Flathead with the front case going off to the side for the generator and the distributor up top. But in this case it's running a magneto so no battery is required to fire it up. Could be 61" or maybe even a 80", but probably NOT the 45".
I blew it up and it's definitely a Harley Flathead, but the crank centerline seems to be about a foot too high to line up with the main flywheel in the drive system. But it could have a gear reduction box to get the crank to the main flywheel input.
Very interesting to all the detail they've put into this if it is a Photoshop.
Still very cool none the less!
Dan
Posts: 27 |
It appears to be real, Polish reg. Search "P-47 "Thunderbolt" H-D WLA Trike" lots of pictures will show.
Posts: 296 Likes: 3
Posts: 296 Likes: 3 |
Fascinating, must be loud with those pipes ![[Linked Image]](https://2.bp.blogspot.com/-wvi_lRp3Jas/WmDF5JB-NfI/AAAAAAACdes/tjBtQSaCucAM1vZf5AUDMHFWslv38DhTgCLcBGAs/s1600/P-47%2BThunderbolt%2B%25E2%2580%2593%2BH-D%2BWLA-Triketumblr_p0lpz2VLZY1qep2npo3_1280.jpg)
2020 M3W
Posts: 902 |
Interesting. Rear wheel drive, external drive shaft on left hand side of car.
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
...which supports the drop gear reduction posited by Dan.
Steve Late 2012 M3W
