+8Rich 93
John V6 49
Posts837,990
rockabilly john
#663789 23/09/20 03:12 PM
3Gs Offline OP
This was in a Pinterest email I received. Does anyone know more about it?
Looks nice, great for "social distancing" and for tall people seeing over the engine would be a good thing, but it does look good.
To me some of the angles, shading & highlights aren't quite right, I suspect it only exists as CAD
Engine somehow reminds me of side valve V twin used in small aircraft tow tractors, maybe JAP??
Many hours of Photoshop. Look at the position of the crank as compared to the belly of the vehicle, it would make for an interesting driveline. Unless it is front wheel drive.
Early Harley Flathead with the front case going off to the side for the generator and the distributor up top. But in this case it's running a magneto so no battery is required to fire it up. Could be 61" or maybe even a 80", but probably NOT the 45".
I blew it up and it's definitely a Harley Flathead, but the crank centerline seems to be about a foot too high to line up with the main flywheel in the drive system. But it could have a gear reduction box to get the crank to the main flywheel input.
Very interesting to all the detail they've put into this if it is a Photoshop.
Still very cool none the less!
Dan
O
O
It appears to be real, Polish reg. Search "P-47 "Thunderbolt" H-D WLA Trike" lots of pictures will show.
Fascinating, must be loud with those pipes
2020 M3W
Interesting. Rear wheel drive, external drive shaft on left hand side of car.
...which supports the drop gear reduction posited by Dan.
Late 2012 M3W
