2 members (Zach, DCH), 222 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
Page 3 of 5 1 2 3 4 5
You are a fine engineer Phil, how about designing a disc brake conversion for the rear?
Having dealt with a stuck brake cylinder piston in the rear brake of my machine (2nd time in it's 8 years life) I would really like to avoid dealing with the drum unit again.
Late 2012 M3W
Originally Posted by Phil Bleazey
I think I have a handle on it now although not a way of fixing the problem. Thanks guys for your input it has helped me see the wood amongst the trees.
It seems that when the rear brake gets hot due to prolonged braking down hill ( my experience ) or if the handbrake has been left partially applied, the drum expands allowing the auto adjuster to go one notch further than normal - it is a very fine ratchet adjuster. This keeps the brake applied generating more heat - gassing off any moisture in the fluid and giving rise to the pedal going to the floor. The only remedy seems to be removing the back wheel, levering the over-tight shoes and brake plate out of the drum, re setting the adjuster and putting it all back together. Change the fluid just in case it has deteriorated and carry on as normal. Short of changing the pitch of the adjuster ratchet I see no obvious way of avoiding this annoying and possibly dangerous glitch from recurring.
As much as I hate to quote other websites....
https://www.gomog.com/allmorgan/APBRAKES.html#SAFETY
The rear drum setup is the same as the trad 4 wheelers, which means that the rear disc conversion I manufacture and sell for those, “should” fit...albeit only half of the kit will be needed
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
There is so much engine braking available you don't need to use the brakes that much, there have been several times when travelling in convoy on Swiss passes the car behind tells me my brake lights are not working, they are working it is simply I don't feel the need use the brakes if you are in the right gear. After 28000 miles my brakes are hardly worn at all.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
The grey light of dawn is such a revealing environment! Even if one made the pitch of the ratchet greater it would still drop over to the next tooth if it was nearly ready to do so - no fix there then. I will be talking to Simon about his disc conversion asap!
Phil the M3W was originally designed with a rear disc brake, and I think a narrow drive belt, but as I understand it MMC then went to a wider belt which presented clearance issues and as result switched to a rear drum which allowed them to move the wheel over.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
JMD Offline
...they moved the wheel over a bit with the silver hubs to allow the drum brake vs the originally planned disc but the alignment did not work reliably hence the need for all of us with early cars to move to the black hub with the wheel positioned to manage the various trade-offs - alpha/beta testers unite!!
Look forward to hearing how the disc conversion might work
I think I have a handle on it now although not a way of fixing the problem. The only remedy seems to be removing the back wheel, levering the over-tight shoes and brake plate out of the drum, re setting the adjuster and putting it all back together.
As usual, good sleuthing and analysis Phil! Rear brake overheating happened to a friend, we think due to a heavy map book sliding off his bag (which was in the passenger footwell) and resting against the handbrake lever. He also experienced the heart-stopping pedal to the floor moment. On that occasion we smelt the unmistakable odour of overheating friction material so left everything to cool down for 20 minutes or so before continuing our journey with trepidation. We didn't really understand what had happened at the time but did relocate the offending map book as a precaution. There was no reoccurance although the brake fluid was replaced fairly soon afterwards.
Incidently, I drove with a seized slave cylinder (and corresponding lack of rear braking) for quite a while without realising anything was amiss (until it was picked up at the next MOT). Therefore, I would just remind anyone who has stripped down the rear brake drum to add a smear of red 'rubber' grease around the slave cylinder pistons before reassembly. They are rather prone to rusting up, especially if driven irresponsibly.
Andy
Will you be marketing your "water cooled braking system" any time soon Andy???
I
I
Those of us that only do “dry miles” have had to lie down. scared
M3W Brooklands (2015)
Moody 41 (2013)
Rog G #664683 28/09/20 02:04 PM
I may have only used my brakes a hand full of times doing the 11 mile "tail of the dragon".... Shifting is what makes driving the M3W fun!
Rodger
2004 Plus 8 (wife's)
