Topics49,908
Posts838,123
Posts: 365 |
1: check/replace (?) the cambelt 2: check rear brake and also adjust so handbrake works 3. fiddle again and change the oil cooling system I have 4. already did fuel pump 5. probably need rear tire 6. rear mud guard
When you have the back wheel out for the tyre change it would be a good thing to replace the cheap and nasty wheel bearings fitted as standard with some better quality items such as SKF Explorer 6205-2RSH. It's an easy job to tap the old ones out with a hammer and a drift and then tap the new ones in. Looks like these bearings are not that expensive are they really that much better? How many bearings do we need to replace?
2017 M3W Sport Green
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
There are two bearings in the rear hub. The original bearings are sealed in lubricant type but the seals fail and allow the grease to escape, then the bearing fails. The SKF ones don't seem to suffer the same problem, better seals.
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
Just booked my M3W in at Krazy Horse this Saturday for 569 cams and unlocked ECU
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 3,733 Likes: 79
Posts: 3,733 Likes: 79 |
Just booked my M3W in at Krazy Horse this Saturday for 569 cams and unlocked ECU   good call
Red Leader
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
You are going to love it!
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I might add..... check the brackets and straps on the fuel tanks....
VERY close to 10,000 miles
Posts: 365 |
I am starting to gather my winter projects. I have Fabian's lightweight steel sprocket coming my way so that is high on the list. I will also install new tires all the way around and the Walbro fuel pump.
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
You moved the turn indicators and added a reflector on the front suspension?
