3 members (JohnHarris, Morganmike, RichardV6), 309 guests, and 32 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,090
Page 3 of 8 1 2 3 4 5 6 7 8
planenut #664884 30/09/20 02:00 AM
Originally Posted by planenut
Originally Posted by rcmatt
1: check/replace (?) the cambelt
2: check rear brake and also adjust so handbrake works
3. fiddle again and change the oil cooling system I have
4. already did fuel pump
5. probably need rear tire
6. rear mud guard
When you have the back wheel out for the tyre change it would be a good thing to replace the cheap and nasty wheel bearings fitted as standard with some better quality items such as SKF Explorer 6205-2RSH. It's an easy job to tap the old ones out with a hammer and a drift and then tap the new ones in.
Looks like these bearings are not that expensive are they really that much better? How many bearings do we need to replace?
2017 M3W Sport Green
2Sharp #664905 30/09/20 07:39 AM
There are two bearings in the rear hub. The original bearings are sealed in lubricant type but the seals fail and allow the grease to escape, then the bearing fails. The SKF ones don't seem to suffer the same problem, better seals.
IMHO #664909 30/09/20 07:53 AM
Just booked my M3W in at Krazy Horse this Saturday for 569 cams and unlocked ECU smile
2015 +4 and 2000 4\4
1981 Lambretta GP225
1960 Lambretta LI 125
hugo #664949 30/09/20 11:02 AM
thumbs good call smile
Red Leader drive
IMHO #664956 30/09/20 11:52 AM
You are going to love it!
IMHO #665267 02/10/20 01:42 PM
I might add..... check the brackets and straps on the fuel tanks....
VERY close to 10,000 miles
Rodger
2004 Plus 8 (wife's)
IMHO #665646 05/10/20 03:04 AM
I am starting to gather my winter projects. I have Fabian's lightweight steel sprocket coming my way so that is high on the list. I will also install new tires all the way around and the Walbro fuel pump.
IMHO #666173 08/10/20 12:40 PM
IMHO #666192 08/10/20 02:17 PM
IMHO #666200 08/10/20 02:51 PM
You moved the turn indicators and added a reflector on the front suspension?
