6 members (Carbuilder, IcePack, John Winn, Topline123, JohnHarris, John Wilcox), 223 guests, and 34 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,042
I take it this picture is a completely different set up on mine ?
Craig Jezz
Thanks all the photos are great every picture tells a story.
Martin R
Yes the setup on mine is totally different but I appreciate the trouble you took
Martin R
I am being to think that a pre1970 cars (mine is 68 69j has different brackets. If I mounted mine as shown in the phots the radiator will sit too high. My top bracket looks the same but the crossbrace is 5/16 dia and doesn’t have a support for the radiator it is only used for holding the radiator in the vertical position via a brace back to the toolbox
Martin R
Yes, you're correct the pre '70 radiators are different, with the tie bar back to the tool box.
That said, the radiator should sit on top of the mounts. Early cars didn't use bobbins and just had a rubber pad with a bolt through it
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Ray Offline
Maybe the short brackets to the chassis are fitted upside down.
Ray #665950 07/10/20 10:38 AM
They're not handed, so one fits upside down anyway.....
Simon @ Sifab.co.uk
Ray Offline
Hadn't thought of that.
As previous comment the brackets are not handed. I can either move the Chassis brackets down so that the rad can sit on the rubbers, make a “U” shaped bracket so the rubber to sit on top of it, OR leave on cotton reels with a keep wire round to prevent the rad from fallin, if the rubber fails
I have taken a photo but the file size is too big
Martin R
Is it the original radiator?
Simon @ Sifab.co.uk
