1 members (ChrisConvertible),
282
40
Topics49,904
Posts838,087
Posts: 132 |
I fitted a remote greasing greasing kit a few months ago.
A week ago, on a grease and inspection job, I noticed that, inevitably I guess, I fitted the plastic pipe incorrectly, and it had snapped off.
So, yesterday, I tried to repair the pipe, and of course, snapped the fitting. I managed to get the stub of the fitting out of the hub, but I've no idea of the thread size I need to replace it.
Help please! 1992 4/4 4str.
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
Help please! 1992 4/4 4str. I strongly advice to get Cain's swivel type fittings. They are smaller,much easier to fit and to connect to the pipe - you just push it in. They are flexible so they permit you to route the pipes in the angle you whish, and they move more or less freely as you turn the steering wheel. Cain has fittings that go to the top of the king pin as well, if you happen to have a grease nipple there too. However, as there is less motion there I do not really think it is needed. But if you decide to change, remember that the thread size is different. Cain will help you.
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Keep a good eye on the pipe. I fitted this sort of conversion to my previous Morgan and eventually found one had blocked and as I was greasing it was simply forcing a grease bubble in the pipe - I went back to grovelling underneath as I do with my current car.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 220 Likes: 4
Posts: 220 Likes: 4 |
Posts: 528 |
For the last 3 years my remote greasing kit has been excellent.
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
Could it be that your damper blade has sheared off the nipple on full lock? remote greasing is not suitable for damper blade cars, at least on the lower fitting.
1993 T16 +4 Lancia Blue.
Posts: 220 Likes: 4
Agreed. Mine is a damper blade car so wouldn't use it.
Posts: 504 Likes: 2
Agreed. Mine is a damper blade car so wouldn't use it. With the old fitting, you are correct. With the new swivel fitting it works. My car has damper blades, and yes - the original kit could not be fitted. So I found these swivel fittings, and there is just enough space. I passed this info on to Cain, who integrated it in his kit. There is a picture of it installed on my car on his website.
