8 members (BHV, John V6, banbury, JohnHarris, TBM, Haggispeed, Carbuilder, David_E),
152
34
Topics49,901
Posts838,045
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
When I bought my 6 year old Brooklands it had 5 new Avon ZV7s fitted. The dealer did this as it was an MOT fail due to cracking. The cracks had been advisories for the 3 years before. See history below Now it had basically stood doing between 800 & 300 miles pa before I bought it at 9000 miles. The dealer initially had only replaced 4 tyres not the spare. If you looked closely at the spare under the tyre dressing the cracks were there so I got a new one as part of the deal.
MORGAN ROADSTER Check another vehicle
Colour Green Fuel type Petrol Date registered 13 June 2014 MOT valid until 9 September 2021 Get an MOT reminderwhen the vehicle's MOT is near its time for renewal.(Opens in a new Window) by email or text.
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA. Open All MOT history Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested 10 September 2020 PASS View test certificate Mileage 9,019 miles MOT test number 5652 9463 8323 Test location View test location Expiry date 9 September 2021 Date tested 23 June 2020 PASS View test certificate Mileage 8,931 miles MOT test number 3559 2936 9205 Test location View test location Expiry date 22 June 2021 Date tested 12 June 2020 FAIL View test certificate Mileage 8,910 miles MOT test number 2892 5018 5792 Test location View test location Do not drive until repaired (dangerous defects): Stop lamp(s) all not working (4.3.1 (a) (iii)) Repair immediately (major defects): Rear fog lamp not working (4.5.1 (a) (ii)) Rear fog lamp switch inoperative (4.5.3 (a) (ii)) Monitor and repair if necessary (advisories): All tyres deteriorating on outer sidewall (Splitting) What are defects and advisories? Date tested 28 May 2019 PASS View test certificate Mileage 8,578 miles MOT test number 7662 9692 0757 Test location View test location Expiry date 12 December 2020 Monitor and repair if necessary (advisories): Tyre slightly damaged/cracking or perishing all tyres (5.2.3 (d) (ii)) What are advisories? Date tested 28 May 2019 FAIL View test certificate Mileage 8,578 miles MOT test number 7522 1907 2779 Test location View test location Repair immediately (major defects): Reversing lamp inoperative (4.6.1 (a)) Nearside Headlamp aim too low (4.1.2 (a)) Monitor and repair if necessary (advisories): Tyre slightly damaged/cracking or perishing all tyres (5.2.3 (d) (ii)) What are defects and advisories? Date tested 21 May 2018 PASS View test certificate Mileage 7,784 miles MOT test number 1083 1070 5544 Test location View test location Expiry date 12 June 2019 Monitor and repair if necessary (advisories): Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i) Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i) All tyres deteriorating What are advisories? The MOT test changed on 20 May 2018 Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested 18 May 2018 FAIL Mileage 7,779 miles MOT test number 7122 9605 2798 Test location View test location Reason(s) for failure Nearside Headlamp aim too high (1.8) Nearside rear brake binding (3.7.B.1) Offside rear brake binding (3.7.B.1) Rear Brakes imbalanced across an axle (3.7.B.5b) Advisory notice item(s) Nearside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i) Offside Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i) All tyres deteriorating
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
Now there is a car that needs using.
